Question about Toshiba 32A33 32" TV
My TV won't respond to the remote control
I've tried several remotes and I know the original one is working as I can see the IR light in a video camera but the TV will not respond. My TV does respond to several channels from the remote , but not to all of them. Would this still be a problem of the RI componant?
    Sergeant:
  • 300 Answers
"My TV does respond to several channels from the remote , but not to all of them."
yoopergal , I know you love the little IR component az do I , The little IR may not be the problem.
What you may me experiencing is a remote control that has become defective or dammaged.
What kind of dammage is anybodies guess.
It could be the CPU inside , or it could be that the little contacts inside are not working.
so you may need to find a Universal Remote and you may want to check to see which one is the best before purchasing one.
When you look for a new (UVR) Universal Remote Control make sure you buy one with an small digital display so that you can see the alpha numerical data output of the remote.
Make sure that the UVR you buy contains the codes for the equipment you already own.
azkeyz@fixya.com
Wizard Division
Posted on Sep 23, 2008
Remote shows flashing light on a digital cam, but TV does not respond.
is that the original remote controller of the tv ?. if so then the problem it could be dirty IR sensor in the tv panel or get bad.
Oct 14, 2012 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
Aug 11, 2010 | RCA Universal Remote Control
Why does my TV not respond to any remote, not even the original remote control. I'm unable to turn on or off or change channels. (Proview 3200)
It can be IR receiver is not working or the CPU is getting the signal from IR board but not processing the signal properly, you can try new IR receiver board.
http://www.shopjimmy.com/led-ir-assy-200-500-hx276-from-proview-3206.htm
Mar 13, 2010 | Televison & Video
I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
Feb 08, 2010 | Logitech Harmony 890 LCD Remote Control
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Sep 03, 2007 | Philips PR0930X 9 in. Portable Television
Toshiba 32A33 32" TV Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
