1999 Dodge Caravan Logo
troy wingfield Posted on Oct 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Diagnostic code P1782 - 1999 Dodge Caravan
Marvin
Level 3:
Top Expert:
  • Dodge Master 85,242 Answers
  • Posted on Oct 20, 2011
Marvin
Dodge Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058064
Points
266281
P1782 DODGE - 2/4-OD Pressure Switch Circuit Possible causes of this code are: - Low transmission fluid level (check level hot transmission only)
- Dirty transmission fluid (has transmission been serivced at least every 60,000 miles, fluid and new filter?)
- Faulty 2/4-OD Pressure Switch
- 2/4-OD Pressure switch poor electrical connection
- 2/4-OD Pressure switch circuit is open or shorted
P1782 DODGE Description The pressure 2/4-OD Pressure Switch is part of the pressure switch of the transmission. The pressure switch are located in the solenoid assembly. The switch provide input information to the Transmission Control Module (TCM). The switch will inform to the TCM is pressure exist in a specified hydraulic circuit. the TCM uses this information to verified that the solenoids are working or not.
Jessie Villarreal
Level 2:
  • Expert 68 Answers
  • Posted on Mar 08, 2019
Jessie Villarreal
Expert
Level 2:
Answers
68
Questions
6
Helped
68725
Points
128
Okay i have a 1998 dodge ram 2500 and i ran a obd ll and it gave me those same codes so i dropped the trans pan and filter , replaced the pressure sensor and the solenoid ,new oil and filter and my p/u runs great and i also changed the shift sensor . You then take the bolts out of the pump plate which is the one that holds the filter or you wont be able to get to the pressure and solenoid , i bought the gasket ,filter ,shift sensor ,pressure sensor and solenoid for $70 but if you buy these parts separate it can get costly at around $250 and thats not including the type of trans oil type plus.
Chrisanne Oliver
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 03, 2019
Chrisanne Oliver
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1265
Points
First things first don't assume the trannys bad if you scan this code that you need a mechanic or transmission needs replaced first think back have you been having trouble imtermitently for a while? Then you might want to take it to a mechanic or was there an event that happened before you started having issues with it such as stuck in the snow, deep mud water hit a road hazard? Everything worked fine until then you should take a look at the hoses, connections, etc. You may have knocked a wire loose, damaged a hose or sensor. Easy to see and repair. Most of the time transmissions last as long as the van if you take care of it. If its fine one day and not shifting the next like mine the transmission is most likly fine I am sure after being the victum of a month of being burried by our rude snow plow operator I damaged someting external when I got stuck on a huge iceball. It knocked a hose off fixed that and replaced fluid so checking wires now since this poor van was so abused before I obtained its a wonder it runs at all. But the tranny and engine are the only things that have no issues its everything else thats falling apart! Check the little things first before you go to a mechanic. A loose wire, low fluid pressure, and such will cause the tranny to malfunction and you will get codes saying that because it is not wirking right fix the cause of the malfunction all codes go away remember the diagnostic system will list many codes because the transmissiin is very complex this does not mean its toast it can't decide so it list everthing that is effected because one little thing got jnocked loise or a hole in a hose. Save yourself being raked over the coals.
I have a e90 bmw and has the code p1782 what does that code mean?
https://www.engine-codes.com/p1782.html P1782 2 4 OD Pressure Switch Circuit
Low Battery Voltage Low transmission fluid level Dirty transmission fluid Faulty 2/4-OD Pressure Switch 2/4-OD Pressure switch poor electrical connection 2/4-OD Pressure switch circuit is open or shorted
Read more: https://www.engine-codes.com/p1782.html
1helpful
Triton not shifting gear
This is an indication that the TCM is not function properly As it is an automatic the gears in constant mesh with gear changes being effected by clutch packs and bands so the ratios are always correct just the selection is not working properly./ Hence the TCM fault.
P1782 and multiple code
I would start with the p1782 the clear the codes. If the check engine light pops back on with the codes, then start replacing them.
P1782 and po700 codes. what are they?
P1782 is 2-4 pressure sense circuit and po700 is internal trans controller. take to a shop .
1helpful
P1782 po700 codes what are they?
2000 caravan with codes p1782 and po700,this is transmission codes, i will tell you this, with out a good scan tool to check the problem correctly you will be just throwing money at it.
this may be due to a bad shift solenoid pack or wiring or internal transmission problems. sorry to say but these transmission are junk.
I would have a transmission shop or dealer check it, maybe the dealer unless you know a good transmission shop that will not try to sell you a rebuilt ******.
3helpful
Check engine light code p1782
Hi, the code P1782 means that 2-4 pressure switch sense circuit FAILURE. It basically means that the transmission solenoid pack needs to be replaced.
2helpful
2answers
My 1999 grand caravan showed codes p1782 & p0700,& it is acting fine & th check engine soon light went off on its own. is there a problem?
p0700 means there is a code stored in the tcm ( transmission control module). P1782 is 2-4 pressure switch sensor sense. This could be just a bad connection or a bad solenoid pack. Many times itis the beginning of the end.
4helpful
Engine light on code p0732, p1782, p1787 and p0700 twice
P0732 Gear 2 Incorrect ratio
P1782 P/ES Circuit Out Of Self Test Range
P1787 2-1 Downshift Error
P0700 Transmission Control System (MIL Request) Malfunction
Here is the deal, u have some serious transmission related faults, in order to sort this out u will need to take this to the dealer, allot of testing is required to get to the bottom of this, if I had to guess I would say the trans is going to have to be overhauled.
15helpful
2answers
What does code p1782 mean
The code P1782 MEANS 2-4 pressure switch sense circuit FAILURE. Basically means that the transmission solenoid pack needs to be replaced. Not a hard job
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
