Question about Bravetti Quad Blade Food Processor
Can't get bowl off base
I got this several years ago and never used it. I can't get the bowl off the base. I have removed all the stuff off the top but it won't release. Is there a button?
Would you like to sell it?
Posted on Jan 23, 2009
I cannot remove the top from the base
I don't know what brand food processor this is. However, are you saying that the bowl will not rotate to release? It's normally just a matter of twisting the bowl (probably anti clockwise when viewed from the top) in order to release it.
Apr 12, 2010 | Cuisinart DLC-5 Food Processor
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
I plug my cuisinart and it will not start. It worked the last time I used.
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 28, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Appears to be locked but won't turn on
Instructions only apply to Cuisinart DLC-2011 series:
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with lid lined up with work bowl handle.
Put pusher sleeve into lid's feed tube, with metal element facing the front of the food processor.
You should now be good to go.
-Tha Mp3 Doctor
Apr 16, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
It just stopped working
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Bravetti Quad Blade Food Processor Logo
105 people viewed this question
Top Bravetti Food Processors Experts
Lawrence Oravetz
ray gallant
Tom Chichester
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
