Question about Amana 3.2 cu. ft. Top-Load Washer
Model# LW6163WM/LM washing machine
Washer fills with water. then the motor overload protector starts clicking
in and out.and there is a burning smell. I am able to spin the water back out.
The belt needs to be replaced but I don't know if that could cause my problem.
  • usaguitarman Sep 26, 2008
    replaced belt and motor machine was unplugged for a while and I still have the same problem.
  • 750 Answers
Dear usaguitarman Welcome to
I'm Huuum and happy to assist you,
You said, washer fills with water. then the motor overload protector starts clicking
Yes I believe the belt could be the problem!
That is more than likely the burning smell!
Change to belt.!
While your at it, unplug the machine for 5 minutes or more and then it will reset the system too!
Let me know how wonderful it performs after these repairs!!!!!!!!!!!!!
i believe you will be fine!
Bless You,
Please do not forget to enter a rating when you are done.
Thank you
Posted on Sep 23, 2008
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Jan 29, 2012 | Speed Queen AWN432 Washer
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Neff W4380X1 -drum does not turn
hi Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs, as detailed in the how to repair appliances article. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.
There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.
Sep 13, 2008 | Neff W4380X1 Front Load Washer
Hotpoint wma58
Could be a bad overload protector in the motor. Some machines have a circuit where the machine rapid advances to the end when the motor overload protector kicks in. This would also make sense that it started happening in the Spin cycle when the motor draws the highest voltage.
Feb 29, 2008 | Hotpoint WMA64 Front Load Washer
Own a Maytag Washing Machine Model No. LAT9416AAE I overloaded with a extra large comforter. I started the cylce and went upstairs to my room leaving it unattended. My parents were down stairs With it, and...
there is a thermal overload protector in the motor. After the motor cools it should restart. There is an off balance switch that might have been tripped when pulling out the comforter or when bailing out the water. As for the belts, tip the machine back and you will see the belts underneath the washer. Very easy to change and you'll see what I mean when you see the belts. That should solve your problem. AND DON'T OVERLOAD THE WASHER AGAIN.
Feb 27, 2008 | Washing Machines
Amana 2002 top loader washer model AlW880QAW
The overload protector is in the motor. Once it heats up, it trips. You likely have something not moving to cause it to trip. Pull your washer forward and tilt it back to about a 45 degree angle. (it will rest against the wall behind it instead of falling forward) Remove the belt and rotate all 3 pulleys to make sure they are moving freely. If the pump pulley (the one on the right hand side)doesn't rotate, you likely have a forign object in there or just a bad pump. If the transmission pulley (the large one in the middle) doesn't rotate, check for forign objectes between the tub and backet. If the one on the left doesn't rotate, it's time for a new motor.
Oct 27, 2007 | Amana ALW880WH Top Load Washer
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
202 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
