2006 Nissan Maxima Logo
Jeannettea Pineapple Posted on Oct 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My radio doesnt work- the radio station is displayed on the screen, however, not able to change station or listen to soun on the speakers. I called my Nissan Dealership and they suggested it being the Circuit Internal fuse now where is this found and how much does it cost. Is this accurate information? Ive also been told to simply remove the batter and connect again. Please advise.
montehammons
Level 3:
  • Nissan Master 5,531 Answers
  • Posted on Oct 22, 2011
montehammons
Nissan Master
Level 3:
Answers
5531
Questions
Helped
1645541
Points
17401
Sounds like it's inside the radio, unless they mean an in-line fuse holder on the power wire leading into your radio. I would ask them again.
I don't think removing battery would help, but no harm in trying. Just take off your negative cable from battery, and it will be totally "as if" removed.
2helpful
2answers
My Chrysler 300 c Radio screen is Blank ,Radio still works but not CD or Sat Nav
It is a known issue
2006 300C Radio Display Has Gone Our, but Radio Still ...
300C Forums https://www.300cforums.com > threads > 2006-300c-r...
Feb 26, 2012 - Then the Radio LCD screen goes blank, but the radio and the preset stations still work fine. Once the LDC screen goes out, the radio controls ...
300C LCD Radio Screen goes out but radio still works?
Feb 26, 2012
8.4 screen blank, HVAC controls not functional
May 23, 2018
300 Stereo Problem (With Picture!)
Jul 26, 2014
2017 300C radio/uconnect issues
Jun 24, 2020
More results from www.300cforums.com
My Chrysler 300c 2006 radio screen is black, on/off work and
JustAnswer https://www.justanswer.com > chrysler > anxib-chrysle...
Sep 8, 2017 - This sounds like the display board in the radio has failed. But try rebooting the radio first by disconnecting the negative battery cable (in ...
1 answer · Top answer: Hello, my name is ***** ***** I will assist you today. This sounds like the display board ...
Q: 2006 Chrysler 300 limited edition radio screen went black.
YourMechanic https://www.yourmechanic.com > Questions
Jan 25, 2017 - I have a 2006 Chrysler 300 limited edition, and the screen went black on my rec nav. I can only change preset stations, eject CDs, adjust volume ...
1 answer · 36 votes: Hello. The issue you are having with your radio is a common problem with Chr
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
2003 monte carlo, radio plays, but none of the buttons work, no display
All you can do is remove the radio and have it repaired by a local approved GM radio repair shop.
1helpful
I accidently did something the display for the clock/radio ??!!! the display previously show time display & now it shows the radio station name RE: the radio station I listen to is 105.7 (KHCB) and ...
continually press/release the center of the tuning know until you have the preferred display you want and then press and hold the same button until the system beeps (1-2 seconds). It will now save your preferred default screen (clock in your case)
1helpful
Radio no audio 1990 bmw 535i
What happens if you turn the VOLUME to MAXIMUM?
If still no sound , then suspect problem with the speaker , connections or wiring
If loud hissing etc. then speakers appear OK so suspect a radio fault
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
2answers
The radio on my 2003 Envoy quit working. The display on the radio says "need amp." A new amp was put in and the radio still does not work. What could be wrong?
Radio sends a 12V signal that switches on the amp which has it's own power suply but won't switch on till signaled from deck. Check to see if the amp is powering up.
1helpful
Bad Radio reception in new 2009 Mazda3 Sport GS model
I would venture a guess that the antenna wire that plugs into the back of the radio is not seated properly. Did the dealer tech just listen to the radio or did he/she actually check the connections on the back of the unit? A faulty antenna connection would explain why it only happens with some stations and not others. Maybe the stations that are not being a problem are transmitting a more powerful signal or are closer in range than the ones that you are having trouble picking up clearly. Just a thought. Hope this helped and best wishes.
7helpful
Can't see anything on the clock/Radio Display
the radio display is lighted by a tiny bulb inside the radio, to change this u must remove the radio from the dash and take off the top sheet metal cover, under that u will see a small twist in bulb socket, replace that little bulb, the bulb is about $2 and avail at any full sevice auto parts store.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
