Question about Garden
RY08510 SPARK DOES NOT FIRE! REPLACED COIL. NEED TO CLEARANCE OF COIL
  • pete46 Oct 14, 2008
    Check gas line. My line from the gas tank to engine had a small **** where it enters the tank. I pulled the the tube further into the tank and replaced spark plug. Unfortunately it still does not start. Do you think the **** in the line is still the problem even though it is inside the gas chamber?
  • Anonymous Nov 25, 2008
    Same problem. Slightly over 2 years old with only about 10 hours on it. Worked fine one day, then 2 weeks later wouldn't start. No spark at all. Tried new plug - nothing. Pulled everything apart to check connections, but everything seems okay.
I am having the same problem with my blower of the same model, no spark. Mine was manufactured in 09-05, so the warranty has ran out. I have not taken it apart yet, is it difficult to take apart and what should I look for? Is there anyway of diagnosing the ignition problem? What do replacement parts cost?
Posted on Sep 29, 2008
    Scholar:
  • 157 Answers
Have you checked your fuel filter? Check the return wire from the magneto on the flywheel & the GND wire connection on the coil. I do need a little more detail in steps you have attempted. I wish you well in your repair.
Posted on Sep 23, 2008
The blower stopped running and hasn't started since. Checked replaced plug and and its not getting any fire What to do?
If you aren't getting any spark then either the coil is bad or the coil is receiving a signal telling it not to fire... in that case, unplug the stop switch and retry.. if it still doesn't fire then the only other thing is to check the coil clearance . Use a business card, stick it between the flywheel magneto.and the coil tips... loosen the bolts on the coil and let the coil stick to the magneto..now tighten back up the bolts, rotate the flywheel as u pull the card out... now try it. If you still have no fire then the verdict is a bad coil..
A repair u can easily do yourself. IF THE UNIT IS WORTH REPAIRING BARRING THE PRICE OF A NEW COIL...
Nov 08, 2015 | Weedeater Garden
Have a 1986 chevy celebrity tec4 an have no fire from coil ive replaced coil checked fuses an have power going to coil still no fire
ignition will trigger if signal from crank sensor, with hei spark plug tester ,read to coil wire and spark plugs wire if spark , depends wich engine
if c3i coil and module the module could be the problems you can check it before replace
hope it helps
Mar 29, 2014 | 1986 Chevrolet Celebrity
Replaced coil on 49cc will not fire
u got spark put a dime in the plug that's the gap u need hope this helps or just a bit of gas into the head where the plug goes good luck
Jan 05, 2014 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
Ok I have no spark on my husqvarna 240 did the coil with the card truck but still no spark
if you checked your clearance and the wire is good going to the plug (no cuts) then most likely bad coil needs replaced.
Nov 07, 2013 | Garden
What will happen if you don't have air gap between coil and flywheel on a small engine
The "Air Gap" is adjusted to create an electromagnetic "charge" between the magnets of the flywheel and the coil of the ignition system. Without the correct clearance it will not produce the spark necessary to fire the spark plug. When the magnets pass closely to the coil, to make it simpler, it produces this "charge" which is then amplified by the coil that can produce as much as 25-50,000 volts
I don't want to make this sound like rocket science, but the fact is if the coil touches the magnets it will wear out the coil and the magnets and not create the right spark. Too much clearance and it will not produce a spark. I first started working with small engines in the early-to-mid 60s and discovered that by taking a sheet of note-book paper and folding it into about three layers thick, placing it between the magnet and coil loosening the coil so that the magnet would pull the coil to make contact and tightening the coil in place. The clearance would then be satisfactory to make a good spark.
It would then be a simple matter to turn the flywheel to rotate the paper out from between the flywheel and coil.
Oct 19, 2013 | 13 HP Electric Start GX390
No fire from spark plug
either spark plug is bad or coil is bad also check clearance between fly wheel and coil
Oct 08, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Would a 2001 chryler town and country faulty engine module cause number 2 cylinder not to fire
not likely, since the engine module also fire the plug across from the #2 cylinder on the coil pack. check for spark directly at the coil, if none is found ,then most likely a bad coil pack.
Jun 11, 2012 | 2002 Chrysler Town & Country
Continualy turning over and wont fire up, Im getting a spark off all 4 plugs carbs appear to be clean just wont fre up
squirt a bit of aerostart in the air cleaner, if that makes it run its a carby fuel problem, if that doesnt make it fire, do compression test, check valve clearance , valve timing
Apr 06, 2010 | 1981 Suzuki GS 750 L
Poulan pro 260
Clearance from coil to flywheel should be around .010
Oct 25, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
397 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
