Question about HP LaserJet 3050 All-In-One Printer
Missing Toner Cartridge
Even though we have replaced the old cartridge with a brand new HP cartridge, the error message reads "No print cartridge." WE have done the usual - reinsert cartridge, unplugged, etc.
  • richnow123 Oct 15, 2008
    No print Cartridge Error Message
    Even though we have replaced the old cartridge with a brand new HP cartridge, the error message reads "No print cartridge." WE have done the usual - reinsert cartridge, unplugged, etc....please help
  • aandwandk Nov 20, 2008
    I tried taking the paper out and reinserting, nothing, still not acknowledging the printer cartridge. Please help
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Posted on Nov 09, 2008
    Problem Solver:
  • 8 Answers
Possibly the chip on the cart is defective. If the chip is faulty then the machine will not pick up the ink. You could try also cleaning the contacts at the back of the housing that holds the cartridges. You will need to wrap a lint free cloth around something lond to reach back there. Use some Isopropyl on the cloth. Hope this helps. Banner Stands from Printdesigns
Posted on Nov 10, 2011
Hp priner model no 3050 fo error no print cartridge
Posted on May 12, 2011
I have a two year old printer not recognizing the cartridge. The print keeps saying "INSTALL BLACK CARTRIDGE". I bought a brand new cartridge and it is not recognizing it. What should I do
You arn't clear whether this message appeared with the old toner cartridge or just with the new cartridge.
If this message just appeared with the new cartridge and not the old one, take it back and get a replacement cartridge.
If the message also appeared with the old cartridge, the printer has a problem with the drum ground connector on the high voltage power supply.
Mar 02, 2011 | HP LaserJet P3005 Printer
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
10.1000 Supply Memory error. How can I fix that?
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
Jun 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
I need to change the cartridge on my HP LaserJet 1020, and I can't find the book detailing how to do it. All I need are the instructions................
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.Follow these steps to make sure the new print cartridge is ready to install into the product.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Dec 09, 2009 | Office Equipment & Supplies
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Print Cartridge Detected is the Wrong Type - error message!
It sounds like the contacts on the cartridge sensor need cleaning.
First remove the cartridge, paper and feed tray. Use compressed air such as "DustFree" or other brand of "canned air" to blow all of the dust and toner out of the cartridge well and paper path. Then, using a lint-free dry cloth, clean the metallic contacts where they mate with the contacts on the cartridge. Just gently rub them off to remove any dust and toner residue. Do not use any liquids or chemicals on the lint-free cloth. If you do not have a lint-free cloth, you may use a clean (read new) rubber pencil eraser. After using the lint-free cloth or pencil eraser, spray the contacts again with canned air.
Reinstall the cartridge and paper and verify that the printer returns to the ready state. If it does not, you need a certified HP technician.
Feb 04, 2009 | HP LaserJet 1200 Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
No Print Cartridge
if this message is present with both old n new catridge,u better check the top cover not properly seated or there is a lever on the right side which is being pulled up by the top cover ,pls check ,it is being properly pulled up by top cover,after pulling up the top cover properly,put the toner catridge ,see its properly seated (horizontally parellen)n check the printer,
do revert
thnx
Jan 26, 2008 | HP LaserJet 3055 All-In-One Printer
Dell a960
I cannot offer a solution. However, I can attest to the EXACT same problem word-for-word. Can someone please suggest a solution?
Sep 10, 2006 | HP PSC 1410v All-in-One Printer
HP LaserJet 3050 All-In-One Printer Logo
226 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
