Galaxy Radios DX- 88HL Base CB Radio Logo
A
Anonymous Posted on Oct 20, 2011
Changing colors on a Galaxy 88 or DX-88HL or DX88
I have a Galaxy DX-88HL(CB Radio), and I am trying to make, or buy a white frequency counter/display. Does anyone know how to make one, or where to buy one? PLEASE HELP!!!
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Oct 22, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1669146
Points
10301
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Have galaxy 88 radio started rx off freq. then a couple days later it started to quite tx and rx while talking. can you help.
It sounds like your crystal has gone bad. More than likely it is the 10.25 crystal. Unfortunately if you have no Oscilloscope then you need to take it to a radio tech as you have to inject a frequency into the triple band to get the radio to Oscillate again, once the crystal is replaced.
Regards, Tony
Haven't used my dx-88hl cb for years. what d9 i set the band on?
I'm not going to be corrected on this as i'm tempted to say A or C and sometime D. Instead i would say switch channel to 19 then watch frequency counter as you change band selector until you find 27.185 and you have arrived.
Hi, my 88 drifts off freq when it warms up. can you help?
  • Is it drifting off frequency by the radios meter or an external meter. If its the radios meter then hook up a meter externally.
Hi, ! boy , I did it this time ? I was changing the meter in my Galaxy 88 , NOW I have a wire that came un-soldered it is in the loom with a red and a white wire that goes to the E-TONE control . This is...
Hi, my name is John. Welcome to FixYa. If I understand you correctly it goes to J3, you will have to look at it real good to make sure. Thanks for choosing FixYa...John
3helpful
My galaxy dx 88 hl makes a laoud noise when you key up and the frequency counter it's off. Channel 19 is on channel 18.
my galaxy 88 cb makes a popping noise through the speaker when I key up how do I solve this problem?
Droped channel to 17 and frequency counter don't work?
sounds like a connection is coming loose inside. take it to a CB shop and see if they can spot it. Should be an easy fix, no more than 20 or 30 dollars
3answers
Galaxy DX 88 HL jumping frequency
sounds to me like a bad PLL chip. but then again, I'm no Master tech myself.
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
