When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airbag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1/2 hour prior.
