Question about Sony Televison & Video
Kd-34xs955 will not come on the on light just blinks
  • Sony Master
  • 8,617 Answers
How many times is it blinking in between pauses? Thats possibly a error code
Posted on Sep 23, 2008
Sony trinitron kd-34xs955 standby light is blinking 7 times
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
As you can see here, seven blinks of standby light is due to some over voltate at the final anode of the picture tube. This is a protection process that going on insde the tV circuits, to prevent more damage to other comnponents on board. The most common cause for this is with the main power regulator out voltage itself. If any way, it ahs exceeded 135VDC, this kind of fault will occur. Check the main power regulator section circuit for any damaged component/s. Replace all the small electrolytic capacitors there. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs. Blinking codes and details are there.
Aug 09, 2012 | Sony FD Trinitron KD-34XS955 34" TV
Sony wega kd 34xs955 won't turn on blinking standby/timer
The blinks of standby LED to Sony TVs are fault indications. You must count its number about how many times it blinks at a time. You can get more details abut the blinking codes and the fault. Visit this site "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
Blinking codes and fault detection methods are described in detail here.
Jun 18, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV will not turn on. I press power and it sounds like it's coming on and then clicks and the stand by light flashes 7 times. Have already tried unplugging and then plugging back in after a minute
When I called a tv repair company the rep said this usually indicates that the "lamp" for this model needs to be replaced. Since he TV is so heavy he suggested that I access the trap door in back of the console and detach the "lamp" myself and bring the lamp to his shop for replacement. Approximate cost for the lamp is $200.00. Wish me luck.
Dec 01, 2011 | Sony FD Trinitron KD-34XS955 34" TV
My Sony FD Trinitron WEGA KD-34XS955 flashes red on the screen and turns off. Why? How can I fix this?
Hi Anita,
The red flashes then get off, usually because there is problem with IC's on its D board ( power supply board) . There are two IC's there and need to replace one or both of them. Since quite hard to do IC's test, I suggest you to replace both of them.
Regards
Sep 26, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi, I have a sony wega KD 34xS955 tv. It had a 10 blink problem. It was the power supply. Its fixed, but need to know how to reset the blinks code. Can you help?
You would not be getting an error code if it was completely fixed. The code is saying that there is still something wrong :(
I would check for thermo sensors or any other type of sensor that could be affected by heat.
on the larger wegas there is a thermo sensor near the bulbs that regulate the tv's power function...if the sensor is blown the tv will no power on.
Please rate if this helped :)
Mar 08, 2011 | Televison & Video
Have enjoyed my KD-34XS955 for the past 5 years.
Maybe the degaussing coil is moved backward from the picture tube.
Jan 06, 2010 | Sony FD Trinitron KD-34XS955 34" TV
Sony trinitron kv36fs13 the picture is fine but there is yellowish green tint on full screen
Yellowish tint in picture shows that TV needs increase in blue gain because picture tube is bit weak in result.
If you are handy with electronics repair then let me know to guide you further.
Jul 12, 2009 | Sony FD Trinitron KD-34XS955 34" TV
Sony kd 34xs955 green color in corner of screen
Is their a speaker or something electronic or electrical near the tv? Move it away, if there is, and see what happens.
Jun 12, 2008 | Sony FD Trinitron KD-34XS955 34" TV
Televison & Video Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
