Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrig model ziss480dmbs
Outer cabinet is sweating underneath the freezer section.
it was sweating in back of freezer section which was stopped by insulation.
was their a problem with this model? can you suggest a fix..
  • 943 Answers
Hi thanks for the question there is a switch inside the fridge called a humidity switch it must have been shut off its located by the freezer fan cover thanks please accept with a positive feed back thanks the appliance doc
Posted on Sep 23, 2008
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a GE profile side x side refrig. The
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
Oct 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Water dispenser doesnt work, ice dispenser works fine
1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)
Jul 19, 2009 | GE GSH25JSSS
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 27, 2009 | Refrigerators
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Old GE refrig is sweating /dripping inside
If you run a 5 inch or so piece of aluminum wire from the defrost heater into the drain hole after you defrost the freezer that should fix the problem for good!
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
104 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
