Question about Samsung HTP-1200 System
SAMSUNG HTP 1200 HOME CINEMA
First poblem. I have a dog that likes chewing things. She managed to chew the din cable connecting the DVD to the sub woofer. I was going to replace it with an original one which Samsung stated howver this was £75 instead I found and identicall one cousting £25. However I am now getting "white type noise" Through all speakers. It isn't conitnous it "pulses" These pulses increase as you turn the volume dial. I have checked and cleaned this with no avail. Is the cable the problem or has the chewing of the cable knackered the insides of the unit.
Also now the DVD/CD player has stopped working. The unit will happily play a CD However when I attempted to play a DVD the disc spins in the unit and the laser doesn't seem to pick up any info from the disc. The unit will then display no disc inserted.
Your help will much appreciated.
  • scousemumble Sep 23, 2008
    THANKS FOR YOUR HELP HOWEVER THE PULSING NOISE ALSO EMITS WHEN PLAYING THROUGH THE AUX INPUT AND RADIO ETC
    Scholar:
  • 55 Answers
I wonder whether your system stood around gathering dust for a while when you were looking for a new cable and that you now have dust on the lense. That could explain the inability to play DVDs and perhaps the noise also.
Could I suggest that you try a lens-cleaning CD, or if you can get at the lens, you could try cleaning it with rubbing alcohol (iso-propyl alcohol) or meths on a cotton-bud.
Chewing the cable could always have shorted something and blown a fuse, or worse, but these don't sound like those types of faults to me.
Posted on Sep 23, 2008
What types of toys should be given to dogs that play for a long period of time?
If your dog is very playful and can keep itself busy for an hour or more a day, then you should give it rope and chew toys.
Aug 23, 2012 | Baby Einstein Dogs
My dog chewed my remote control for my home theater system (ht-c550) i cannot program my time warner (cable) remote control to turn if off or on, have to do it manually. could you either tell me how to...
Dog chewed my .... A first for FixYa.
In the USA look at; www.remotes.com
For the original remote. That should solve part of your problem. What to do about the dog is another story.
Mar 22, 2011 | Samsung Televison & Video
Some weeks ago the sub stopped working. Thought dog had chewed the coaxial driver cable, but not shorted (now). Tried another sub w/o success.
Hi, I went to the Denon website and they have no documentation there for your receiver.
But do not frown, I have some good suggestions for you.
0 Don't beat the dog. After all, it's their job to chew things.
1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2
2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub.
Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub.
You will need the following adapters.
1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone).
2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks.
3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends.
1 and 2 above may be available as a single unit combined with each other.
Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends.
This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz.
I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. .
Then adjust the woofer volume control in a similar manner.
If it all works out, give the dog a treat and enjoy yourself.
I really hope this helps, I love my sub woofer as well.
Let me know how this turns out.
If you have any questions please post them on the site and I'll get back to you ASAP.
Best Regards,
Mark
Jan 22, 2011 | Denon AVR-3600
Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Jan 03, 2010 | Samsung HTP-1200 System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Connecting up a home cinema kit
Heya,
The good news is that the monitor and the Home cinema can be connected but you need to get a cable. Bad news is the cable did not come with it.
The monitor has D-SUB, DVI-D
so you need a HDMI to DVI-D connector then you need another cable to route the audio to the system which you should have.
like ebay item
Item number: 220341264176Hope it helps
Jan 10, 2009 | Wharfedale Televison & Video
I need a cable
Which cable did the dog chew on? I looked on sony's web site you can buy it direct from them. If its a common cable I suggest www.cyberguys.com
Jan 08, 2008 | Sony SRS-D5100 Computer Speakers
Not getting sorround sound from my tv
only the hd channels get great surround sound. if your tv has an optical audio out and your surround has the optical in input. then i suggest buying a fiber optic wire for the audio you'll hear a big differance. just hope that the audio stays in sync unlike my cheap *** koss system
Dec 10, 2007 | Samsung HTP-1200 System
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Samsung HTP-1200 System Logo
191 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
