Question about Electronics - Others
Pool Timer Switch with Transformer Intermatic T10004RT3
The yellow timer wheel does not keep time. I can pull it towards me to set the time but it will not keep time on its own. So I have to manually turn the switch on and off. Is there a simple solution without having to replace the whole unit?
    Problem Solver:
  • 6 Answers
You need pull the interior out by pressing the clip on the top and pivoting it to release or removing the three small screws holding it in(depending on how old it is). I'm assuming it's an Intermatic brand by the yellow dial. The timer motor is bad. It will still run until it gets to the time clock trips, then it stops. It is held in by two small screws. The clock has a number in it for replacement. They run about $25. so it's cheaper than a whole clock, plus you dont have to change the whole thing. That's really all that can go bad on those. They are very dependable units.
Posted on Nov 26, 2008
I want to use this Transformer to power my 12 volt lights in my trailer using a 7 blade connector that is already installed on my trailer. How do I connect the wiring n the ac nle
The two wires are meant to be connected to the 120 volt source. The box or the papers with the transformer should tell you which two of the three wires provides the 12 volt output. If not connect the two wires to the 120V source - Be CAREFUL! - 120V is dangerous. Then try, one at a time, touching each of the three combinations of wires (1&2, 1&3, 2&3) to the contacts on a 12 V incandescent lamp (very bottom and threaded side) the 12V pair will give you the brightest light. The other two are 6v.
I can't address the 7 blade connector without more information. I suggest that you go to a place that sells trailer parts.
Not knowing anything about your trailer I don't know if a 2 amp (2000 ma) transformer will supply enough current to do the job.
Nov 19, 2013 | Philmore TR212 12 Volt AC Power...
When pluged in my ego-ctwist cig isn't showing its charging the light just stays yellow not blinking
Your lighter may have a short or is not pulling enuf power to charge you ego
Feb 06, 2013 | Electronics - Others
How do I turn off timer on a 3 button led light
because that is the auto-shut off feature. It's meant really for closet space and not for anything else.
Oct 29, 2012 | Sylvania LED 3-Button Silver Round Dragon...
No spark on Makita Generator G5501R
Atlas Machinery Supply Ltd.
233 Queen Street West
Toronto, Ontario, Canada
M5V 1Z4
(416) 598-3553
info@atlas-machinery.com
Apr 29, 2010 | Electronics - Others
User manuel for westinghouse outdoor digital power
Go to http://www.thencc.com/ncc/support.html and type in 28011 as the model number. Click on the word "instructions" for a .pdf 1 page instruction sheet.
JL
Nov 28, 2009 | Electronics - Others
Our timer has a red pin and green pin how do we set the timer? We cant find the instructions from last year we used it for our Christmas lights. It is just a small timer.
Put red pin in one spot put green pin in another pluged lights into timer continued to turn until lights came on and went off
Nov 19, 2009 | Electronics - Others
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20...
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Jul 12, 2009 | Electronics - Others
I need a wiring diagram for a Intermatic T104 40-amp timer
http://www.intermatic.com/images/instruction_sheets/T104.pdf
http://www.intermatic.com/Default.asp?action=cat&cid=91
if the 1st link doesn't work, use the 2nd and look for ur timer model there for the diagram.
if u need more help than this just ask
Tip: i usually use a photo cell in combination with the timer. i set the time for winter hours and let the photo cell take care of the rest.
Jan 02, 2009 | Electronics - Others
WIRING PULL SWITCH
yes but be sure to turn the power off first a switch is basically a break in the active wire so put your pull switch as being that break glenn.....
Nov 22, 2008 | Electronics - Others
Pool motor wiring
I assume you mean a gfci recepticle? If this is the case you need to take the black wire from the house and pigtail it to go to both the recepticle (Black / Line) and one line side screw of the switch. The white wire from the house goes directly to the line/white side of the recepticle. Also pigtail the ground to go to the green screw on the recepticle, the green screw on the switch, the green wire from the motor, and the ground screw on whatever box you're using. When you purchase the switch make sure you get a two pole switch rated for at least the amperage of the motor. The red wire from the house and the black wire from the pigtailed black will go to the two line side screws of that switch. The red and black from the motor will go to the two screws on the load side of that switch. Make sure to ground everything properly being so close to water. The cover needs to be sealed securely and I recommend the cover that has the lever to activate the switch as opposed to the little door over the switch handle. Also make sure the two breakers supplying those two circuits have a handle that turns them both off at the same time.
Sep 01, 2008 | Energizer Rechargable Battery with Charger
Electronics - Others Logo
583 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
