SCRATCH IN SCREEN - Televison & Video
    Sergeant:
  • 300 Answers
REPLACE SCREEN
Thank you for choosing FixYa!
Az. Wizard Division.
Posted on Sep 23, 2008
How to remove scratches from iPhone screen?
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
Aug 11, 2016 | Apple iPhone 6
Can I fix or cover up small scratch on my iPhone?
discuss the problem with a phone repair shop as it may have a glass screen before the led screen that can be replaced
Jan 16, 2016 | Apple iPhone Cell Phones
Scratch on screen of LCD TV
Check by wipe the screen with a soft cloth dipped in glycerin.
Dec 09, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I repair a scratch on the screen of LCD tv?
You have not mentioned which part of the screen is the scratch?? Anyway please note that you can not apply a chemical on the scratch. Just leave it and clean it with a slightly damp cloth as long as it does not affect the viewing of the picture on the screen.
May 22, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Scratch on the screen
the screen cannot be repaired but it can be replaced.
In order to avoid seeing the scratch on your screen again, you have to change the screen completely.
It is not possible for a screen that has scratch to be repaired.
Good luck.
Apr 12, 2010 | JVC HD-52G786 52" Rear Projection HDTV
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Scratch on plasma screen
    You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
    Jun 21, 2009 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
    Scratch in sreen
    By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
    The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
    Jan 07, 2009 | Toshiba 61HX70 61" Rear Projection...
    Scratches in my LCD Television Screen (sony bravia) How will I fix this?
    Easiest solution is the stuff you buy to fix your glasses with (Lens cpr), so long as it's a small scratch. Larger scratches don't try to fix you can damage the screen further.
    Other solutions (though I recommend only at your own risk)
    Vaseline Method
    Clean the surface of the screen.
    Take some Vaseline and fill the scratch with it.
    Gently wipe off the excess Vaseline, being careful not to press too deeply so as to leave some inside the scratch.
    Voila. This works because the optical density more closely matches the LCD face than air.
    Pencil Eraser Method
    Find a pencil with a clean, soft eraser. It must have no pencil graphite on it as you won't want to smudge that on your monitor.
    Lightly rub the eraser over the scratch or nick on the screen.
    Keep rubbing until the scratch completely disappears [1].
    Sep 02, 2008 | Televison & Video
    Unfortunately, no. The protective screen has to be replaced. Is it a scratch for sure, or possibly a spider web inside?
    Feb 25, 2008 | Sony KP-51WS500 51" Rear Projection...
    Televison & Video Logo
    35 people viewed this question
    Top Televison & Video Experts
