Question about JVC HD-52G886 52" Rear Projection HDTV
Digital blocks appear
I can see digital blocks when I am watching something that has a dark scene in it such as a night scene or dark clothing...etc
What is the fix for this or is there something wrong with the tv?
  • raosti Sep 30, 2008
    We have the JVC HD-52G887 and had the cable company (a while back) and direct TV (today) here with different boxes and nothing helps. However the Direct TV guy stomped his foot in front of the TV and it changed to a clear picture, but when he walked away it changed back, apparently something is loose!
The HD-ILA's do not handle dark content well, it's a known problem. As far as intermittent digital blocks while viewing regular content it may be coming from your sat/cable company or you may have a problem with the digital board. I've had a few of these go bad.
Posted on Oct 22, 2008
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
I have a Mitsubishi DLP WD-57831 and the dark colors are hazy/milky on the screen, and the lighter colors look normal. There's a 'ghosting' effect which makes it difficult to watch night time/dark scenes. ...
This tv require projection colors lens R,G,B clean and it coolant chemical replacement.Should check for it prices by a tv shop or shops for best prices for it services.
Feb 01, 2011 | Mitsubishi WD57831 Television
Nights seens are WAY to DARK
do you know what a g2/focus splitter looks like?
if so and you can get to it, adjust the g2 controls ever so slightly.
Sep 08, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Panasonic PT-61G63W Too much Black Serial No: MY83430025
The mirror should also be cleaned. but there is more adjustments that can bring up brightnes ie G2 on the flyback transformers but that is some thing a tech should do. Because you have to ad enough of each color to get a gray scale. if you are off the picture will be tinted and your color will be way off.
Dec 26, 2007 | Panasonic PT-61G54 61" Rear Projection...
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Night or dark scenes are too black
take your set to a tech for adjustment of the focus.
Apr 03, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC HD-52G886 52" Rear Projection HDTV Logo
62 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
