Question about HP DesignJet 1050c plus InkJet Printer
Print head failures HP 1050c
I have an HP 1050c that has went through 3 black print heads in 2 weeks they were all first quality HP parts. When replacing the printhead it appears to fix the problem for a few days then it alarms out that the black print head needs replaced. Any help would be appreciated.
Danny
  • 4 more comments
  • Beach Bubby Oct 16, 2008
    we ordered and installed the tube system, it appeared to have worked for a few days with a new print head then it killed the print head again. $400 tube system and $100 print head shot. Any other suggestions?
  • Beach Bubby Oct 21, 2008
    The contacts were cleaned throughly in the beginning and then again when I installed the tube system. Someone mentioned seeing an error #21 but I do not recall seeing it. I do not know how to put the machine in service mode or how to run service tests.
  • Beach Bubby Oct 22, 2008
    I ran each of these tests and they all passed, while I was there I tested the ink pressure as well and it passed. The drop test hole had a large build up of ink that stuck to my eraser when I pulled it out.
  • Beach Bubby Oct 29, 2008
    I have attempted to print out the report. The black started printing ok but by the time it got to the info on the black print head it is unreadable. It says its ok and that it has 2 hours service. I have replaced the print head cleaners every time. When i put the ink tube system in i replaced all 4 print heads and print head cleaners. It fails calibration and says to replace the black print head.
  • Anonymous Mar 27, 2014
    Printer hp 7525 printhead problem
  • Anonymous Mar 31, 2014
    what is replace 21 mean?
  • HP Expert
  • 141 Answers
The tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Posted on Oct 02, 2008
  • 2 more comments
  • steve shroder Oct 16, 2008
    1. have you thoroughly cleaned the flex ( copper colored ) contacts in the carriage?
    2. Is the machine making any strange noises or giving any strange error codes? 3. do you know how to put the machine in service mode and run the service tests?
  • steve shroder Oct 22, 2008
    to run service tests, power on the machine holding the color button down until the display reads initializing. to put the machine in service mode from a normal ready screen push the down button until you are on the printer icon. hit enter then scroll to utilities then hit enter then push the up and enter buttons simultaneously. 1. if in service mode run the service station calibration.2. if in service tests, run the drop detector test. when it asks you to block then stick a pencil eraser in the hole to the right directly inside the right cover. the hole is rectangular shaped approximately 1.25 inches x .33 inch. if the drop detector test fails then it must be replaced. if it passes then perform the electronics test. this test will tell you if you have a bad carriage or electronics module. let me know what happens.
    print a service print by going to the printer icon, hit enter, then go to utilities,
    hit enter, then test prints, hit enter, then service print. look for error codes and printhead info. did you or did you not perform the service station calibration? have you been replacing the printhead cleaners everytime you replaced the printheads? this is brainstorming, bear with me. I always figure them out.
  • steve shroder Nov 01, 2008
    unfortunately it sounds as though the carriage pca (board) is and/or has died. this means the carriage must be replaced. while i was at it, i would replace the belt if if has not been replaced in a couple years. the logic is that the machine will be torn down to the same point whether you are replacing the carriage or the belt, so you might as well knock it out while you're there. If you need instructions on carriage and/or belt replacement, please post and i will lay it out for you. good luck!
Push power button on front panel and print head carriage zooms behind ink station and crashes.....
Manually try to pull out service station(where print head cleaners located)., feeling very hard?.. cleaning and lubrication required.. Remove right cover., cheat the door sensor., switch on the printer & check for the where is the abstraction?.. If found any paper particles, remove & try.. Still problem persists, service station required over haul & lubrication.. But only professionals can perform this activity., ..
Note: Don't switch on the printer without print heads..Once printer treats no print heads in carriage, it will ask for health print heads for alignment., result you need to spend for full set of print heads.. be care full..
Mar 28, 2015 | HP DesignJet 1050c InkJet Printer
Changed black ink but it still prints very very lite and only part of the document.
Hi
Try to make print nozzle for 2-3 times to clean the print head.
If not, adjust the print quality from text to photo.
Regards.
Feb 19, 2011 | HP Photosmart 3210 Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Sep 16, 2009 | HP DesignJet 1050c InkJet Printer
Hp Deskjet 1050C Plus- Print head error
It is not unheard of to have a bad print head out of the box. I suggest you remove all the print heads and clean the ribbon connectors in the carriage that connect to the print heads. Clean the connectors on the print heads also.
If that does not clear up the problem, you may have a bad trailing cable (carries all the signals to and from the print heads) or a bad carriage.
Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Download Service Manual: www.lpscomputer.com/ec/manuals.htm
Jun 09, 2009 | HP DesignJet 1050c plus InkJet Printer
Bad print head
HP C5010DN(Black) and C5011DN(color) are the part numbers. I am surprised staples does not carry them, but you should call around to local stores that sell printers. In Canada I use Future Shop or Best Buy.
Dec 05, 2008 | HP OfficeJet d145 InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
2,594 people viewed this question
Seeker5211
Seeker5211
