Question about Cameras
Ricoh Caplio R5. Have used cable transfer of pictures to my PC twice , but now the plug will not enter the camera socket.
    President:
  • 1,952 Answers
Change ur camera cable port...then connect the camera and pc thro the data cable and transfer the picture to pc....without cable also u can transfer picture with the help of memory card reader ... just use memory card reader and insert ur memory card in to it and transfer the picture to pc..even i too face the same problem...i rectified by this above mention solution only...tats y am suggesting this to do
thanks for using fixya
rate this solution
Posted on Sep 23, 2008
    Master:
  • 763 Answers
Sir what do you mean about cant enter camera socket? are you using usb cable? if your camera used previously with your computer and it has no problem then the reason is your cable. it must be the pin of the end of your wire got disalign. if that's not the problem then reinstall the driver camed with your camera to your pc so that it will be recognizable once again. you can transfer your pictures by using your usb cable. it also included on the box of your camera which you have both.
CHARCOIS
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to replaced your usb plug
or removed the memory card and plug in
memory card reader!!!
if you want to move the pic to the computer
Where can I obtain a driver for Caplio R5 Camera Windows 7
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 02, 2012 | Ricoh Caplio R5 Digital Camera
I borrowed a Caplio R5 camera, have taken some super pics, but couldn't download onto computer. So took the memory stick to Boots and their developer couldn't find the photos. Put the memory stick...
The Photo's are currently stored on the cameras internal memory, you'll need to transfer them to the card using the camera's menu options.
Failing that, plug the camera into your PC and switch on, a box should appear asking you which programme would you like to access the new device with.
Select the folder option, then click on and open any folders therein, one will be the camera memory the other the card memory.
Jul 04, 2011 | Ricoh Caplio R5 Digital Camera
The image taken by my Ricoh Caplio R5 has horizontal lines across it. This happened after I deleted the previous images ready to start afresh. I then bought a new SD card to see if that resolved the...
Hi
The fact that the lines started appearing when you deleted images from the Ricoh Caplio R5 is probably coincidental.
It sound as if the problem is a faulty image sensor (sometimes incorrectly called the CCD or CMOS sensor, depending on what type).
If it's under warranty, contact Ricoh and have them repair it.
Regards
David
Jan 13, 2011 | Ricoh Caplio R5 Digital Camera
Broken LCD Screen
Send it in for service...they'll replace the screen.
Aug 28, 2009 | Ricoh Caplio R5 Digital Camera
My computer won't pick up my ricoh caplio r5 camera even though it's connected via the cable, i've tried changing comouter ports with the cable
First download the latest drivers, then turn on camera and program if you are using one, then lastly connect cable
Aug 01, 2009 | Ricoh Caplio R5 Digital Camera
Ricoh Caplio R5 Digital camera
Not many but a FUJIFILM 1 gb card will do the trick
Nov 26, 2007 | Ricoh Caplio R5 Digital Camera
Ricoh caplio R5 digital camera
Flash not working Reset the ISO setting to a higher number Invest in a good image editor or even download the free Picasa
Aug 02, 2007 | Ricoh Caplio R5 Digital Camera
Cameras Logo
61 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
