Question about Akai CTS2550 25" TV
Colour Problem with AKAI Ninja CT 20MN TV
I'm having AKAI Ninja CT 20MN TV (20''). The problem with this TV is there is very less intensity of Red colour and intensity of yellow colour is very high. When I make colour setting as 0 there is no tint (i.e. completly mono or Black and white). Please provide me solution for this, my mail id is hkulshreshtha@gmail.com.
AJIN G
  • 6694 Answers
SOURCE: AKAI Colour Television CT-1419A/AT plus AKAI
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Posted on Aug 20, 2011
BDEATH
  • 58 Answers
SOURCE: Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Posted on Sep 04, 2007
  • 1694 Answers
SOURCE: AKAI TELEVISION
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Posted on Dec 03, 2007
  • 20 Answers
SOURCE: AKAI CT-2107DT
Try holding both volume buttons on the t.v. down at the same time.
Posted on Mar 19, 2008
SOURCE: AKAI TV UNLOCK
i wish i could
Posted on Oct 14, 2008
Color prolume in Akai CT-20MN MK iii
What is the problem with color to your set? Provide more details, please. Check its system settings too; like PAL, NTSC, SECAM etc. Gopakumar Gopalan Google
May 03, 2014 | Akai CTS2550 25" TV
I want to purchase the entire Main Board of Akai 25" CRT Tv
Try for it by ebay, alibaba.com or rss.com. 25" colour TV kits are available at open electronic spare part market too.
Jun 22, 2013 | Televison & Video
I am having Akai CT-2180 Colour TV. My mechanic has informed that its sound coil is out of order and it is not available in the market. Can you guide me as to where it can be available
I do not understand it well. Sound coil? What sound coil? There is a voice coil. But it is inside the speaker. If it has damaged, will be very difficult to replace. Speaker should be replaced. If this coil has damaged, you won't get sound from your TV. That is all. Picture will be there.
Ask your technician to give you the number of part [sound coil], that he has detected faulty. Send that number to me. OK?
May 31, 2012 | Televison & Video
Have a akai tv that's has a green or yellow tint
Hello
Check the picture tube base card for any loose solderings. Your TV lacks Blue colour putput. Check all the solder points on this board. Resolder all the susepected solder terminals [especially take care to blue output section], by applying a little more solder. Check the base connection solder terminals of the blue output transistor. It might be loose, or transistor is defective.
Mar 29, 2012 | Akai Televison & Video
How do i adjust the color on my tv
go to the main menu and select colour and adjust using the up/down keys. you can also adjust the contrast slightly to achieve the intensity of light that you require
Sep 18, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
How do connect the RCA cables?
Match colours (red and white for right and left sound) and yellow for graphics/video. Remember there is an input and output component. Sif you wanna connect like a DVD player to the TV, then use the output section of the DVD player and input section of the TV; since it will send data 'outwards' and then 'into' the TV.
kc
Mar 09, 2011 | Akai PDP4225M 42 in. Plasma Television
MY AKAI CT-20BS PICTURE GET INTO GREEN COLOUR, HOW I RESTORED
Hey
could be two problems
1. The blue and red electron guns are dead! in which case you need to replace whole unit.
2. The blue and red electron gun driver transistors are shorted..if you have a bit of experience in electronics i can talk you through it is easy!
let me know
hope this helps,ben!
Jan 04, 2011 | Televison & Video
Problem with akai lct 2016
you can buy the new power supply on ebay for less then $20
Aug 28, 2009 | Akai LCT2060 Television
Akai CTS2550 25" TV Logo
177 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
