No REWIND I HAVE A AIWA TP-1002 REELTO REEL RECORDER. ALL OF THE BUTTONS WORK FINE BUT THE REWIND DOES NOT WORK. WITHOUT REELS ON THE RECORDER WHEN IN REWIND ONE REEL GOES CLOCKWISE AND THE OTHER GOES COUNTER CLOCK WISE. IT RECORDS FIND. PLAY FIND JUST THE REWIND. ALL BELTS ON ON THE UNIT. WHERE CAN I DOWNLOAD A FREE SERVICE MANUAL FOR THIS UNIT. HOPE YOU CAN HELP. THANKS JACK HERE IS MY EMAIL ADDRESS JACK1ROX1@CAROLINA.RR.COM
Maanita
  • 1142 Answers
SOURCE: Nakamichi BX-2 Cassette Deck Takeup Reel
It seems to be a hardware issue please go through this manual this will help you resolve the issue.
www.analogstereo.com/nakamichi/pdf/nakamichi_bx2_owners_manual.pdf
Posted on Apr 06, 2008
welcomejee
  • 10594 Answers
SOURCE: problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Posted on Oct 22, 2008
SOURCE: i need a service/owners manual fora tascam 38 reel
they are available on ebay, but not free.
Posted on Mar 07, 2009
SOURCE: Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Posted on Aug 20, 2009
  • 4 Answers
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Posted on Aug 31, 2009
Pioneer rt707 ...ff & rewind buttons work...play
I have not seen a RT707 but in the RT909 there are reel settings for the reel motors as far as torque goes. A copy of the service manual will tell you how to set these tensions. I suspect that you have a setting that favors one direction.
Feb 01, 2013 | Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
AIWA AD-F810 reel torque
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Feb 11, 2012 | Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
Kustom Eyewitness VHS stops recording randomly.
The tape is not being pulled through the mechanism properly, and/ or the take up reel is not turning.
Motion is initiated by a motor and transferred by means of belts and pulleys to a clutch and drive assembly, which drives the reels. If any of these slip, the reels will fail to turn. I would replace the belts, idler and clutch assemblies and make sure the pulley and reel surfaces were extremely clean/
May 02, 2017 | Panasonic Televison & Video
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Apr 08, 2009 | Audio Players & Recorders
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
87 people viewed this question
 Grubhead
Grubhead
