Question about Canon Office Equipment & Supplies
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some matter inside the paper shute (a dead cockroach!). I have removed the matter, but the printer now comes up with 'Print head out of alignment' or 'Print head is not compatible and needs replacing' (error U051 and u052). I have tried removing and re-installing the printhead but the error message remains. Is my only option to buy a new printhead? It seemed to be working until the paper jammed from the blockage. Thanks
  • Anonymous Feb 26, 2009
    I have been getting the error message U051 relplace the print head. The printer is used pretty regularly and the temperature climate has not changed severly. I have tried new ink cartrages and I have taken out the print head and examined it and nothing seems to help. I figure I will have to buy a new print head. That sucks! I hope this is the answer to my problems!
    Sergeant:
  • 300 Answers
Yes vintos after long storage problems with the printer heads may arrise.
Thermal changes from being in storage can cause the printer heads to dry up and fail.
DO NOT USE ALCOHOL or other solvents in an attempt to clear the printer heads.
1. Attempt to change ink cartridges , this may clear the issue.
If that fails , you may be forced to change printer heads at that point.
Link to Printer Trouble Shooting. ( generic steps for all printers )
http://www.duxcw.com/digest/Howto/troubleshoot/print/index.html
Thank you for choosing FixYa!
Az. Wizard Division.
Posted on Sep 23, 2008
2 Suggested Answers
solofixya
  • 34 Answers
SOURCE: I have just re-started my
I would suggest removing the printhead, make sure there are no more dead roach's under the printhead, also make sure all lights on the ink tanks are lite up, the first error code you mentioned has to do with the ink tanks, the second one has to do with the printhead. I would suggest un-installing the printhead, then reinstalling it doing the alignment, and that should clear the error code.
Posted on Nov 13, 2008
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
Need service manual for Canon PIXMA MP610
Hello friend, you can find the canon mp610 service manual in below link:
Canon mp610 service manual:
http://goo.gl/yB52u6
thanks
Oct 12, 2011 | Canon PIXMA MP610 InkJet Printer
Cannot print my canon mp610
Ok...if you have it installled in your computer you have several options.
1 Restart the pc
2. Take it out and reinstall it
3. Sysytem restore
4. Restart the printer.
5 look on bottom right hand corner of you moniyor and see if you have pending prints. Cancel all.
Nov 03, 2010 | Canon PIXMA MP610 InkJet Printer
My Canon Pixma MP610 won't power up. I've
You've eliminated all other options, so obviously your printer is defective.
Call canon if it is under warranty, otherwise you will have to replace it.
Apr 08, 2010 | Canon PIXMA MP610 InkJet Printer
User manual printer mp610 wanted
Canon pixma mp610 is one of the best All-In-One printer which can turn your home in to an office. It has 4,608-nozzle print head and can print 4" x 6" photos with spectacular 9600 x 2400 color dpi resolution which is its maximum resolution. It takes some around 21 seconds for the same. canon pixma mp610 also has a provision for the memory cards. You may preview the images in the 2.5" TFT display.
Apr 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My canon pixma iP4300 printer wont take up the paper.I sounds to be working OK, but paper seems to start Ok on right hand side , but not left side, after sometime moving about 4inches , then twists, if it...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-29
Jun 14, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
May 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP610 bluetooth not working
I can print to my cannon mp610 using my bluetooth connection, but cannot scan using it. Any ideas?
Jan 17, 2009 | Canon MP610 Photo All-In-One Printer
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
Sep 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
804 people viewed this question
old marine
old marine
