A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection. If that doesn't help, try the steps below: 1. Disconnect the printer from your computer. 2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds. 2. On your computer, go to Control Panel > Printers
and Faxes. 3. Delete the Lexmark print object. 4. Reboot your pc. 5. When your pc turns on, reconnect the printer. 6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to print a document again to
verify that the problem is fixed. I hope this helps.
SOURCE: scanning with my printer
Funny you just posted this yesterday and I had the same problem at the same time. (driver timb bomb?) Any way, the solution that worked for me was to: 1. Unplug the printer. 2. Uninstall the drivers. 3. Reboot the machine. 4. Go to the lexmark site and download the drivers. 5. Install the new drivers. Everything is working great now. It is nice to have simple solutions once in a while. :)
SOURCE: cannot retrieve application list on scanner
try boosting the power couplings followed by initiating the inter-active recipter valve. Once you see the deflanger code type in +.ak234//pp.HO.
This open up the transducer allowing the flow of typherical codes that was being block preventing you scanner from downloading the application list.
If this doesn't work, write your Congressman.
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
854
SOURCE: Cannot scan anything on my lexmark 4550
There is a patch that you can download and run to resolve this issue.
Step 1:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500.exe
If the problem still exists, follow Step 2 below.
Step 2:
Download the following patch: http://swdownloads.lexmark.com/Patches/3500-4500/3500-4500wifiethernetpatch.exe
If the problem is still the same
1.Get the printer ip address of the printer (ex: 192.168.1.10)
-press settings on the printer panel.. go to network setup.. View TCP / IP, open a browser (IE or mozilla) and type in the printer ip address
-you will see the printer page and then go to configuration.. choose scan to network host
-delete all the computer name listed
2. Go to start, all program.. choose Lexmark 3500-4500 series and choose Lexmark Solution Center
-go to Advanced, click on networking and then click on Change PC name or PIN
--rename the PC name and then click on Ok
3. Turn off the printer, unplug it for 10 secs
4. Try to scan, it should work
if it's still the same you need to uninstall the printer driver and download the updated driver in Lexmark.com
-reinstall it using the downloaded driver
GOODLUCK!!!
SOURCE: I want to scan a
A problem occurs with your scan driver. You will need to reinstall it to correct the problem.
Another way to scan is to use the scanner option in your computer. Go to Control Panel. Double click the Scanners & Cameras icon. Feed your documents in the printer before starting the scan process.
Try it.
Please give this answer a four thumbs up rating it this help you.
Thank you for using Fixya
