Message: Press enter to align cartridge, this has been carried out several times - next message alignment cancelled
    Genius:
  • 2,120 Answers
You must replace both ink cartridges for align cartridge to work.
Posted on Sep 23, 2008
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
My Lexmark 5600 series will not align properly. Ink levels are both within operating levels, above 75% Will not print documents. The LCD screen flickers up and down, pixels are all scrambled. I have...
Pull out the cartridges and clean any residual glue on the bottom of them by scratching them with your fingernail. Wipe the contacts in the printer and the cartridge with a LINT FREE cloth. Gently replace the cartridges. If they don't go in easily then you're doing it wrong. Clean and realign the cartridges. If these steps don't work then the only thing you can do is hit the cancel (red x) button on the printer to bypass the message for every print job you do.
May 31, 2011 | Office Equipment & Supplies
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to tools...to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Is it possible to override or cancel the
No, you need to replace all ink carts with Genuine HP carts to get a sucessful alignment.
Jan 20, 2010 | HP FAX 1250 Fax Machine (Black)
Printer error on sharp ux-b700 new cartridge?
Try to reinstall the cartridge and press NEW, then go through alignment process.
Dec 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
71 people viewed this question
k24674
