Question about HP OfficeJet 7410 All-In-One InkJet Printer
Unable to scan
I appear not to be able to scan on my HP officejet all in one printer - i don't have the options microsoft word - i only have options :
HP Document Viewer
HP Image Zone
HP Instant Share
E-Mail
Paint
I have reloaded the software disc but still I am unable to scan - can yo help?
Thank you.
  • AZ2370 Sep 30, 2008
    I have the same problem and have recently re-installed my printer with the HP disk on my computer but now (for the scanner only) I get a "you need to install or run HP software for this feature". I do not have word etc on this computer-do I need to install micorsoft Word?
  • 234 Answers
Make sure you have microsoft word installed i you computer.
But if you want to scan a document you can also scan it to HP Document Viewer.
First open solution center/HP Director and try to scan from document> then in the optin which says where do you want to send the scanned image> click on the drop down and check to see yu have the option of word> if yes select the option of word and try to scan.
If not Open HP Solution center/HP Director and go to settings> Scan settings> Scan to setup> Go to> Destination List> And click on Restore defaults and check to see if you have the option of word in the availabe list and front panel destination list> then click on apply ad ok and close all the windows and then try and check to see if you get the option of scan to word.
Posted on Sep 24, 2008
Can I scan on HP officejet pro L7650 all-in-one
Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
Feb 13, 2015 | HP Officejet Pro L7650 Printer
When I try to scan a document on my HP Officejet 4500, a box appears stating the LCD list needs upgraded. What does that mean, how do I do that and why hasn't this happened before when I scanned?
This means the printer has lost the front panel menu items, likely due to some Microsoft update or firewall update in the computer.
Launch the HP solution center on the computer. Click the SETTINGS button. Hover over or click the SCAN SETTINGS button, and choose SCAN TO SETUP. Add or remove items depending on the options you wish to be available at the time of scan, and click UPDATE DEVICE.
Your scan options should now be available from the front panel of the device.
If this did not work, try again in 30 minutes.
If this still didn't work, you may need to uninstall and reinstall the software.
NOTE: these instructions assume you are using the CUE13 (black interface) software.
If you are not, uninstall the software and drivers for the printer that you are using, and go to the HP website, and get the latest drivers and CUE software.
Jul 22, 2011 | HP Officejet 6500 Wireless All-in-One...
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
I am unable to scan from my 5788 or my 5180 to my hp pavilion lap top. The 5788 window says "no scan options" in the printer window. I have the printer connected directly to a USB port, I have rebooted bot...
You need to have the HP scan software running on your computer before you press scan, the scan options are in the scanning software and the scanner needs to know where to send the image, how to scan, and what type of image you're scanning.
Oct 12, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Sep 23, 2009 | HP Officejet 6500 Wireless All-in-One...
Hp officejet j5780, NOT SCANNING
go to www.hp.com and download a new driver of your scaner for xp
Jul 03, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet 4255 unable to scan
reinstall printer drive use the software that came with printer
Mar 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Need to scan - unable to on my HP officejet 5610xi All-in-One
open control panel -> go to scanners and cameras -> start the hp officejet 5610xi -> then it should start enjoi :)
Jan 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
312 people viewed this question
Seeker5211
Seeker5211
