Question about Bosch Classixx WFL 2066 Front Load Washer
Troubleshooting My Bosch maxx 6 washer indictes a "F16" error on the panel. Now what ???
  • Anonymous Apr 21, 2009
    My Bosch maxx 7 washer indictes a "F16" error on the panel. I closed the door well,still mothing...
  • Anonymous Mar 29, 2014
    operating manual in english
I had that. closed the door properly and it went away
Posted on Oct 07, 2008
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
I get the F:16 error nearly every time I run my Bosch front loading Maxx 7 washer. I've cleaned out the water filter on the intake line, blown compressed air in the line...many times that will do it, but...
F16 has to do with your door lock. you probably have a faulty door lock. the machine senses the door is open and will stop. the door lock isnt that expensive and should solve your problem. if that doesn't solve it then you may have a faulty control board. but i would first start with the lock
Feb 05, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
1,735 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
