Question about Xerox DocuColor 12 Printer
Web roller display shows the massage to change the web roller soon. then i change the roller but the massege is still on display how can i clear the massage
  • Steven Brown May 11, 2010
    Please specify the Brand Name and Model Number of your product.
    Thank you for choosing FixYa!
    Az. Wizard Division.
This can be solved in resetting the nvm codes
777-077 and 777-078 to 0.
Posted on Sep 24, 2008
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
Sir i have micromax q50 ezpad, i am facing problem to open massege menu, shows alway loadind, and internet menu shows always internet service not ready, kindy help me
actully sir i have micromax Q5 and i m facing the problems like the massage menu is not opening , defult web browser is also not opening ...
Aug 07, 2011 | Cell Phones
Will not show delivery reports
You need to configure back your SMS setting.
Just go menu -- massege and massage setting.
Check your delivery report setting and change
Nov 21, 2010 | Cell Phones
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
Wrong cartridge
I had the same problem. The Canon web site recommends resetting the print heads, but this didn't work for me. Here's a link to their recommended solutions:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Dec 17, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Tally T8106
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  • Power the printer on while holding down MENU/ENTER key
  • Release the key when the display shows "Utility Menu Clear FC. Roll"
  • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
  • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
  • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jan 28, 2008 | Tally T8106 Laser Printer
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Error Message ('replace belt CG')
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Xerox DocuColor 12 Printer Logo
228 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
