Question about Dishwashers
MATSUI DISHWASHER MS160SL. IT STICKS HALFWAY THROUGH THE WASH PROGRAMME. IT IS NOT GETTING HOT. DONT KNOW IF ONE PROBLEM IS CAUSING THE OTHER IE IF THE ELEMENT NOT HEATING IS CAUSING THE PROGRAMME NOT TO MOVE ON.
  • 4 more comments
  • soc601 Nov 17, 2008
    To the previous post, can anybody supply me with a user manual for this dishwasher. Moved into a house, no instructions for dishwasher. soc601@hotmail.co.uk
  • 24716728 Dec 18, 2008
    Thanks for your input. I have just replaced the element, but same problem. Hammer is the next option methinks!!!
  • hucster0 Jan 14, 2009
    Hi did you find the answer to your dishwasher problem? i have the same dishwasher with the same problem. I tried replacing the programmer to the tune of £40 and it didn't fix it. Thinking maybe i should change the heating element now if you can help me please can you email me a response to huckle_7650@yahoo.com
  • taz9219 Jan 20, 2009
    Only completes the rinse cycle. Trips the switch 50% of the time. dishwasher repair man fitted a new element but this has still not fixed the problem. Has anyone found the solution ?
  • Anonymous Feb 20, 2009
    i have the same issue, i have changed the heating element and the programmer.. still no joy!!!!! i feel like chucking the thing in a skip any ideas to sort this PLEASE
  • judithdavejo Apr 10, 2009
    I HAVE THE SAME PROBLEM WITH MY MATSUI MS160SL THAT THE MACHINE STICK IN THE MIDDLE OF THE WASH PROGRAMME. iHAVE READ HOW OTHERS HAVE TRIED THE HEATING ELEMENT AND ALSO THE PROGRAMMER AND STILL HAVE THE SAME FAULT HAS ANYONE GOT A SOLUTION YET.
    D JOHNSON. staffs
I have the same problem and have found that it is caused by as you suspected a burned out heater element. they can be purchased on the web for £15.95 at partmaster .co.uk
Posted on Sep 29, 2008
  • fatoskizilka Dec 20, 2010
    i have same problem with everyone else i do think this is the factory fault.i paid already £11 for online answer i do not know should i get heating element?
  • fatoskizi543 Mar 02, 2011
    thank you micka10 i did changed heater element but problem is program does not run normal.l mean it got stack and i need to turn it by manual.what is your experince?
Matsui MS160SL dishwasher not working.
To wash dishes you can use a bucket to fill the washer. Things to check are the float in the washer that regulates the fill level. Make sure it is not stuck, if that is okay, check the filter at the water inlet to the washer. It should have a screen on it. It might be blocked. To check that you have to pull it out if it is a in the counter mounted unit. If there are no debris in the filter, check the voltage on the water valve. If you have voltage the valve is bad, if not voltage the controller is bad.
Sep 05, 2012 | Dishwashers
Matsui ms160sl manual
Please Visit thishttp://kitchen.manualsonline.com/ex/product/headline/m/matsui/d/dishwasher/p/ms160
Please click 'Get this Manual' button and Enter your Email and Postal CodeYour manual starts downloading
Thanks!
Jan 02, 2012 | Dishwashers
Hi Colin, I need to find a manual for my dishwasher. Its aMatsui M12FDW09 any advice would be great thanks. Dishwasher start to make strange noise and the water is not coming through to start the first ...
Hi Colin,
Please click the link below to download the manual for the Matsui M12FDW09:
http://www.partmaster.co.uk/company/partmaster/manuals/M12FDW09_IB_GB_FINAL_091110.pdf
The manual is in English. Please ignore the Japanese text on the cover. Unfortunately, it's unlikely having the manual will help you identify the cause of the fault.
I'm assuming the flashing light you are referring to is numbered 1 in the control panel diagram on page 2 (the 5th page of the PDF manual). This light simply indicates the dishwasher is in the pre-rinse stage of the wash cycle. Your description suggests the solenoid has failed, so the water inlet valve isn't opening and no water is entering the dishwasher.
I only repair Matsui washers on call-out as they are a Dixon's Stores Group (DSG) only brand in the UK, so I don't see that many of them and can't get service manuals. I can diagnose and fix them when they're in front of me, but I couldn't tell you from memory how to get access to the components and test them.
I hope this helps you a little, even though it doesn't really solve your problem.
Regards, BElectric
Oct 20, 2011 | Dishwashers
Dishwasher leaves baked on soap scum on al dishes and everything ....even on the dishwasher ...tried all kinds of soap and rinse aid...nothing works...cleaned entire washer out cleaned all filters...
I imagine you've already checked that you're using the correct amount of detergent for the wash programme, and that you're washing the correct quantity of dishes for the wash programme, though if not, try that first!
Is the dishwasher heating the water to the correct temperature? If it's not rinsing at a hot enough temperature, the detergent may leave a residue. In that case, your dishes would probably also be less than entirely clean; they could be slightly greasy when removed from the machine.
Another possibility is that insufficient water is supplied to the dishwasher, so it might be worth checking the tap that lets water through the hose and into the machine. Does the tap turn on fully? Does it turn off properly?
The other thing that might be worth trying is an empty wash: put the machine through a wash programme WITH detergent but WITHOUT dishes, at the programme with the highest temperature. Is all the soap scum washed away? Or is there still a residue inside the machine? If the empty wash works, you probably need to give your machine a maintenance wash once a month or so. This is often the case if you usually wash your dishes a few at a time on a short programme.
I hope some of that helps. Good luck!
Oct 09, 2010 | Bosch Dishwashers
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Diplomat Dishwasher motor cutting out on hot mid cycle
Hi ,This problem is your main wash motor the origonal is an ascol
motor ,but the replacement is a motor with copasiter costs
around £80.00 for new motor
Nov 19, 2009 | Dishwashers
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
I have a matsui dishwasher and it keeps sticking in the middle of a programme and then i can not reset it please can someone tell me how to reset the programme
I have a matsui dishwasher and i am having the same problem with the sticking please help someone what do i do.
May 08, 2009 | Dishwashers
My matsui mf2w/a dishwasher sticks during cycle. normally about 10 minutes into the wash. i can move it on manually but the wash is poor. the water does not appear to be heating
check the safety thermostat which is located at the bottom of the dishwasher. you have to remove the bottom plate,and then you will find easily the thermostat-KSD201/PF 90. you have to reset this probably.there is a red wax dot in the middle this thermostat, so remove it and use a needle to press a very small button inside. the heating element is working well probably.you can measure resistance on it to be sure.
Dec 02, 2008 | Dishwashers
Dishwashers Logo
2,046 people viewed this question
Top Dishwashers Experts
