Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
  • Walter Shadick
    Walter Shadick Oct 21, 2011
    Found the Service Manual. BUT Not able to run Diagnostic. Only thing that really works is the Cancel. When pushed always come on with a 2 on the display and sounds like it is trying to drain. HELP
  • Walter Shadick
    Walter Shadick Nov 01, 2011
    All Switches work. Can not run Diagnostics, Nor reset controls. Need Schematic for Control Board
Have Whirlpool GU1500XTLT1 with similar symptoms (nothing works but NORMAL WASH and RINSE ONLY light blink, tried power off but they resumed blinking. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with different problem, and it worked: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Posted on Feb 20, 2012
    New Friend:
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Posted on Nov 01, 2011
SOURCE:
Whirlpool quiet partner iv. Turn breaker off then on. Displays 4H then goes off few mins later. Press the cancel button and then the POTS AND PANS along with NORMAL buttons start flashing back and forth.
this is not from me but i found it and am passing on..
Hi
Thanks for using FixYa. Error code 4h means 4 hour delay start which means that the dishwasher is in delay start mode and has been set to 4 hours. You can either wait for 4 hrs or to start it immediately press the cancel button to cancel the delay start option. After this program the cycle and options and press Start again as the dishwasher will not start the wash until it reaches the delayed hour i.e. till 4hrs. If after 4 hrs still the light blinks and it wont start then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 28, 2017 | Whirlpool Dishwashers
What is the sequence to reset kenmore dishwasher 665.16819992? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, water Heat, no Heat dry, delay Hours,...
You haven't said why it needs reset, so possibly it can't be reset if there is a mechanical or electrical problem with a part in the dishwasher.
Here is a link to a page on YouTube. They usually have good repair videos and how to videos:
https://www.youtube.com/results?search_query=how+to+reset+kenmore+dishwasher+665.16819992
Mar 04, 2015 | Kenmore Dishwashers
How do i reset the consol on a westinghouse dishwasher with the buttons rinse only, quick wash, china crystal, normal, pots and pans, soak and scour, hi temp scour, sani scour, air dry and cancel?
Normally you will have to press High Temp and Air dry button alternatively 3 to 4 times within 8 secs until the whole panel lights up. Then press Cancel. That should reset the dishwasher.
Hope this helps. Welcome to fixya.com.. It is a public forum and you can also answer questions by selecting Solve Problems and answering solutions for problems on categories that you are comfortable with.
May 03, 2014 | Westinghouse Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore dishwasher 665-17829000
Check the control panel ribbon cable that plugs into the control board behind it. If everything works well, you will need to replace the control panel. You provide me with the colour or your appliance, I will supply you with a part #.
Mar 11, 2014 | Dishwashers
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
471 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
