Question about Brother MFC-5440 Printer
Brother MFC-5440CN Everytime I SCAN (using the feed tray on top) a legal-size document part of the the document is left off.  I've set the Brother MFC-5440CN to legal-size and the ControlCenter 2.0 to legal size, but it still won't work.  However, when I put ONE-sheet-at-time on the scanner-bed-tray (excuse my terminology), it works.  Feeding the docs thru the tray one top is ideal because I have 39-pages (all legal size)...and need them all in one file.  Please help...thanks.
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
  • 832 Answers
SOURCE: OCR with Brother MFC 5440CN
you can program by help of the brother control center. open cc and set readiris as the ocr prog. (actually the paperport prog has a built-in ocr engine)
Posted on Apr 11, 2008
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
SOURCE: Full-Screen configuration for MFC-5440CN
Well, the configuration panel has two sections, Software Button and Device Button. It's not self evident, but you must set the update paramet BOTH on the first AND on the second.
God knows why make things complicated when they be simple!!
Posted on Nov 13, 2008
  • 65 Answers
SOURCE: does the mfc 7420 scan legal size docs?
Yes. You could look at the printer specifications.
Posted on Mar 27, 2009
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
How can you scan a legal size paper on this machine.
Put the document throught the ADF (Automatic document feeder) as opposed to on the scan bed.
Make sure you have legal paper in the tray and the tray is adjusted properly
Jan 06, 2011 | Brother MFC-7340 All-In-One Laser Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
May 11, 2010 | Brother MFC-5890cn Color Flatbed...
Brother 9840CDW won't scan/fax legal size pages from glass or ADF
Is a setting in the printer.
Go to start >Brother> start center> on top go to configuration. then it will ask you for a password. use "access" for the password.
click on general setup and you'll see document scan at the bottom.
Change it from letter to legal and apply.
Sep 02, 2009 | Brother MFC-9840CDW Laser Printer
How do i reset my scanner on the brother mfc-6490cw all-in-one printer/scannner/fax so i can scan in legal size documents? now i can only scan in letter size.
Launch scanning utility from computer instead of using the scan button on the Brother. Tha will give you more options. You also may need to configure the Brother software settings.
Aug 10, 2009 | Office Equipment & Supplies
Nov 13, 2008 | Brother MFC-5440CN All-In-One InkJet...
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at: at 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
mabey try using windows, not linux, make sure you have driver and other software on CD.
Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440 Printer Logo
73 people viewed this question
James Cagle
James Cagle
Jim Keysor
