Question about Goodman Heating & Cooling
Janitrol furnance blower motor shuts off when AC unit is running. LED is flashing short to ground If you place the thermostat in the fan on position it runs fine, but constantly
  • 182 Answers
Sounds like your control board is shorted.Without actually checking the unit this is a guess.
Posted on Sep 23, 2008
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Furnance running all the time never shuts off
Turn the thermostats fan position to Auto instead of ON. If it already is in Auto, then there is a fan relay stuck in the board.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
The fan motor is on all the time with the controls shut off. I have to shut the unit off with the main breaker. The ac works but again the fan never shuts off. On the circuit board the LED flashes 8 times,...
The indoor fan or the outdoor fan? If it is the indoor fan the thermostat may be wired incorrectly or shorted. If the red wire and green wire in your thermostat maintain contact, the indoor fan will run all the time.
Aug 03, 2011 | Heating & Cooling
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Have a Janitrol central air system and the unit outside comes on but the fan in attic does not always come on. If I go to the thermostat and manually turn it from auto to on it comes on. Any ideas about...
If the blower is working with the thermostat in the ON position that tells you that the fan motor works. In the AUTO setting... the system in controlled by the contacts in the thermostat. 1. The thermostat contacts might not be closing. 2. A contactor( or relay ) in the air handler unit(inside unit) might not be closing to send the signal to the fan motor. It sounds like a thermostat or relay problem to me. You can email me at Starztruck4u@aol.com if you have more questions.
Aug 05, 2010 | Heating & Cooling
Goodman A18-8 electronic furnance and AC troubleshooting.
Check the unit for a high temperature limit switch, usually a round bimetal disc or a square plate that
would insert into the unit. If the switch is bad, it opens up and the fan will run no matter what. Complete the circuit with jumper wire, if fan shuts off
replace switch
Jun 12, 2010 | Goodman GMS90703BXA Heater
Indoor fan motor continue to run even if the thermostat is in auto position with the cool and heat switch in the off position. The furnance don't have a fan on and off switch in the furnance like most....
Try this, disconnect the fanwire (green) on the furnace, if it shuts off then the hot wire from the thermostat is touching the green wire or bad thermostat. Thank-you-very-much!
Aug 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
