Question about VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09)
Pc monitor problem
Hi can you please help me,after cleaning up my proccessor in my pc,i put it back in and the monitor won't work,so i tried the poccessor in another pc,no joy when i put that pc's proccessor back in ,the same thing is happening with that pc now,no picture on the monitor,i've tried another monitor,still the same,here's hoping you can help.many thanks.al
  • 43AL Sep 25, 2008
2w2qq2q2q
Posted on Sep 25, 2008
My toshiba l675d-s7013 laptop screen won't come on?
hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Dec 02, 2012 | Toshiba Satellite Computers & Internet
Inspiron 580 freezes randomly. Help out please
it looks like your pc is overheating. try to remove your proccessor fan, put proccessor pasta on the top of your proccessor, put the fan back and check the proccessor fan speed inside bios setup.... try to turn on your pc only with mainboard, memory, and proccessor.... unhook everything else... see if it still freeze... hope this will help...
Jun 17, 2012 | Computers & Internet
I put a new proccessor in to my acer desktop and it turns on but i get no signal on my monitor and the cd drive beeps once every 10 seconds and the hard drive light is at first lit up and then it goes...
hi there tommy,hmm you may need a new installation of windows(or whatever Operating system you may be running on your system),let me know if you have fixed your issue elsehow..
Regards, Finphillips
Please rate me
Dec 22, 2010 | Acer Aspireā„¢ T180 PC Desktop
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
Pc problem
try to reset the bios,
Jun 16, 2009 | Foxconn (865G7MC-ES) Motherboard
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Overheating again!!!!!!
place the fan in the most conveniant place to cool down what ever it is you want to cool ie the case
good luck
Terry
Mar 10, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
THE LAPTOP WILL NOT START PROPERLY
The solution to your problem is probably not the monitor, follow these steps:
1. Connect and boot your computer with 2 different monitors.
2. If it does'nt work with either of them the problem is from another computer component.
Posible Problems:
1. Your video card may be damaged or moved from it's slot.
2. Your proccessor may be damaged.
Posible solutions:
1. If you have computer hardware knowledge open the case
2. Remove the Video card.
3. Insert it back or insert another video card from a friend.(if it works with your friends card, obviously the video card is the problem)
4. Restart your computer and see if it works.
Now if it does'nt work after that you will have to replace your proccessor with one that works, from a friend, because you say your computer boots but if your monitor doesn't work you don't know for sure if it boots corectly.
The steps above are only for people with hardware knowledge, if that is not your case you should contact a computer service.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 14, 2008 | Toshiba Satellite M30X Notebook
TOSHIBA TE2100
This can be caused by:
1.The monitor is not connected properly.
2. Bad hardware
Verify that the monitor is properly connected in the back of the monitor as well as to the back of the computer.
If the connections are OK it means that monitor or the video card is probably damaged. To test which component is dameged connect a different monitor to your computer or connect your monitor to a different computer.
If the other monitor works on your computer it means that your monitor is bad and if your monitor works on another computer it means that you probably have a damaged video card.
or
Posible Problems:
Posible solutions:
Jan 23, 2008 | Computers & Internet
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
