Question about Ricoh Aficio 1013F Copier
Need a program/software/driver to print
Hi there
I have a Aficio 1013 fax and printer, my computer needed repairs and returned without the program in my fax and printers, now I am unable to print from my computer and I am not very computer literate.
Would you perhaps be able to help me?
Kind regards.
David du Preez
  • Ricoh Master
  • 2,794 Answers
I have Printer and Scanner type: ricoh aficio sp 1000sf But now I don't have driver for it So, I need printer driver, scanner and fax driver of ricoh aficio sp 1000sf
Hi Mach,
Click on the download link below to goto the driver and software download page of Ricoh.
Download Link
E.g : If I want the printer/scan/fax driver for windows 7, I will click on the download icon under Windows 7 as shown in the image.
shreysri_7.png Regards,
Shrey
Jun 02, 2011 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Ricoh Aficio 1013f is duplicating print under each line. Happens on copying, printing and faxing. Have changed process drum unit twice in the last year, fuser unit and had unit cleaned. Was better for...
What type of environment is this copier in? Standard office, warehouse, etc. If the temperature in the area fluctuates a lot, that could have something to do with your problem. Usually ghosting problems like that originate in the fuser. Try increasing or decreasing the fuser temperature to see if that fixes the issue.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
I tried to fax from my computer using the x7170, but it only prints. I can fax from the machine. Is there another software I need, or driver? Thanks, Ken
Hello. Make sure that the fax software is already installed in the computer. There should be a fax object in Printers and Faxes/Printer/Printers and Devices(for Windows) or in Print and Fax(for Macintosh). If there is, when you send a fax from the computer, make sure to use the correct print object which is for the fax. If driver is not installed, reinstall the software.
Mar 07, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I am unable to print. I try to print word, excel or tax return document but it is automatically going to fax. I again and again cancel the fax screen and then again click print and it going to fax screen...
If you recently installed the printer or other programs in your computer then this problem occured. You may just need to reinstall the printer on your computer with your disc that came with the printer. What may of happened is that the program or updates that were installed deleted your print driver. To fix just reinstall and you should be fine. This is nothing you did wrong just the way things happen. Also you can check in your control panel and make sure your printer is turned on as your default printer.
Jan 18, 2010 | HP Officejet 6310 All-In-One InkJet...
Even though my RICOH Aficio 1013 appears to be an ALL-IN-ONE, the ONLY function it now porforms that of a copier. What components do I need to add or install to get to function as a printer, scanner, &...
It would be cheaper to find a 1013spf meaning scan,print,fax. Finding all of the boards, wiring harness, ROM chips and control panel buttons needed to convert your machine would be pricy. Then you would need a service tech to install everything as well. You can find the "spf" versions used for less than $1,000 and you could get around $500 for yours.
Jan 15, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Faxing, printing and receivng faxes.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr2
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Trying to scan w/ Ricoh Aficio SP C210sf
Could be a driver issue. Go to: http://www.ricoh-usa.com/downloads/software.asp?tsn=Ricoh-usa and find, download and install the driver for your Ricoh device.
Jun 11, 2009 | Ricoh Aficio SP-C210SF Printer
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
100 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
