PC Monitor My icons are all blurry and fuzzy. Everything on screen is. Any ideas.
  • jopsey Sep 25, 2008
    HOW DO YOU DO THAT.
    Thanks
    Problem Solver:
  • 7 Answers
In side of your monitor there is something which yiu can adjust to focus it, all I know is that you better have it unplugged for awhile to let the power drain, and its alittle thingy you need a small screw driver to do.. if some one could explain this process better, it would help alot of people.
Posted on Oct 01, 2008
    Champion:
  • 293 Answers
Jopsey,
Try adjusting the WB (white blance) on your Monitor. That should come back to normal setting.
Good lucks!
Posted on Sep 24, 2008
  • Cj T
    Cj T Sep 25, 2008
    Jopsey,
    Well, by open your monitor OSD (on screen display). After that just look for white blance or image settings. if can't find it just reset to factory settings. If still have a same problems... Unplugged your VGA cable see if any damaged or just replaced another cable. Also make sure you are not running on safe mode cuz that will give you a fuzzy and blurry screen as well. Have a nice day!
My monitor is fuzzy in internet
Fuzzy on the internet and everything else or fuzzy just on the internet? check for monitor resolution and see if you have the screen resolution set right. If you have the resolution set too low, the screen can appear more fuzzy if the aspect ratio is not set right.
Jun 04, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Iphone 4 screen has gone fuzzy and blurry
time to replace you digitizer and screen. We do it for 99.95 with return shipping.
Feb 18, 2014 | Apple iPhone Smartphone
My iphone screen is fuzzy and blurry
Your screen is demaget, change with new
Acer flat panel monitor with dell dimension 4600 desktop, i am having a resolution problem. Icons are blurry, or fuzzy. the computer does not have a DVI port to connect to the monitor. I have used only VGA...
the issue is most likely the resolution you set the panel to. also make sure you select a generic flat panel driver under the Display properties EXP: if your panel is a 17" Panel chosse 1a driver with a max resolution of 1024X768 @ 60hz to start and go on from there you will solve it.. let me know if you need more help.. Marcelo
Aug 06, 2011 | Dell Dimension 4600 PC Desktop
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
My Lenovo y510 display is blurry. Sometimes it
Need a replacement soon.
If you want a temporary solution for your eyes, use a regular monitor, and plug it to the laptop
Don't forget to rate if this answer helps
Jul 20, 2009 | Lenovo IdeaPad Y510 Notebook
I have an HP Pavilion laptop and when I closed my monitor (while it the computer was still on), I reopened it and it went black and then reappeared to windows but the icons looked bigger and fuzzy, almost...
This sounds like a changed resolution problem. You can find the properties of the monitor by finding a open space on the desktop screen and left clicking on it . Click on the setting tab and adjust to your viewing preference. or you can go to start and then open the control panel in windows. Go to display and open it. Click on the settings tab and check the resolution settings. If you have the owners manual handy check for the manufacturers setting. Then try resetting the resolution of the screen to your viewing preference. I hope this information helps you with your problem.
Jan 14, 2009 | HP W22 LCD Monitor
My letters on the screeen ar blurry look like a bad copy and I can't read anything-also , everything on the screen kind of shifted to the left so I can't see my back button for example or like half of my...
Is you monitor an LCD?
Did you change the resolution you are running at? LCD's dont really like being run at anything but there native resolution.
If not, try the OSD settings. The monitor most likely has buttons on the front of sides to control them. Dont worry, ther isnt anything in there that can cause harm to your screen.
Dec 01, 2008 | Computers & Internet
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Blurriness/Fuzziness
Hi, Using the OSD, select the Auto image adjust.
Sep 15, 2007 | ViewSonic VA703B LCD Monitor
Computers & Internet Logo
1,310 people viewed this question
David Payne
David Payne
