Question about Lexmark X3550 All-In-One Printer
Printer problem Paper twisting and will not feed through printer
  • lizet21 Oct 14, 2008
    the paper only goes to leftside of the printer and makes a lot noise, and does not print.
    Genius:
  • 1,847 Answers
Clean the rollar with little alcohol and then try.
Hope this help.Thanks.
Posted on Sep 23, 2008
Feeder in my canon mg5250 is not working properly. It seems to feed one side and twists the paper and then sticks.
Did you check, nothing is in the paper feeder? Could be just a little piece of paper or a staple is blocking proper functioning of the feeder.
Keep the paper try clean and take care you never drop or leave anything in the printer, that does not belong there.
Mar 08, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper not feeding through
Help...paper not feeding right. It twists before it even gets in the the printer. thanks Joan
Feb 12, 2011 | Canon MP490 InkJet Printer
My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I Have Canon MP600. The paper twists when I start printing copies. Ihave cleaned Paper Feed Rollers. It still twists paper When printing.
You need to look down inside where the paper goes, I use a flashlight and small mirror. I find things like candy,screws, gum wrappers, caught way down where they are hard to remove.
Aug 19, 2009 | Office Equipment & Supplies
When paper feeds it twists and unable to print
How old is your printer? What tends to happen with most rollers is that the rollers that grab the paper, lose their stickiness after much use. These rollers tend to get kind of smooth. What you need to do is grab an eraser, the kind we used to use in school and try and erase all around the roller until it feels "rougher." This will aid in helping to feed the paper without any problems. Good luck.
Apr 18, 2009 | Computers & Internet
Paper twists when feeding
there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Card Stock is Not Fed from the Bypass Tray
Check the inside of the printer, ensure that there is no paper or foreign object stuck, sometimes they go undetected and they can affect normal printer feeding.
Try pulling out the paper tray and check the paper feeding mechanics underneath the printer.
Usually feeding problems are mechanic, if you cannot fix them in this simple way you will need to take printer apart and check feeding traction mechanics, this is usually a job that is better done at a repair shop.
Aug 11, 2008 | Ricoh Aficio CL2000N Laser Printer
Epson Stylus RX425
First remove the paper and tip the printer onto its back and give it a shake to see if anything comes out from the paper feed. Next try a piece of stiff card approx A4 size and insert this where the paper feeds into the printer. Give it a good wiggle and push it the the printer, watch the inside to see what is pushed out. I have found everything from plant leaves to a golf tee!
Jul 26, 2008 | Epson Stylus RX425 Multifunction...
Lexmark X3550 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
