Tape deck my sharp GF9292 is 15yrs old .The problem is i play tape or radio the sparkling sound is coming but their is no spark plz solve the problem.
SOURCE: Technics RS-TR272 dual cassette deck
My RS-TR272 tape deck plays the cassette but no sound. I have not even used it much, may be 3-4 times in last five years. I tried demagnetizing it but still no effect. It is brand new unit, only thing I did last time was that plugged in the RCA cables in opposite ways one time (Output in In and In into output one). I am not sure if that had any bad effect on it. Can someone please help on this as unit shows cassette playing. There is no volume switch on the unit itself as someone else recommended in the previous answer.
Posted on Nov 25, 2007
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
SOURCE: Tape deck won't play
my machine not working problem is play, fd,rw, is not working all three led of rec,pause,play led is blinking
Posted on Dec 08, 2008
Grubhead
  • 5309 Answers
SOURCE: Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Posted on Aug 06, 2009
dunnbiker
  • 8546 Answers
SOURCE: When i push play on either deck - the tape starts
If you observe the sprockets in the cassette you'll probably see they're not turning. That would indicate a broken belt or something mechanically common to both decks. Deck logic probably interprets the lack of sprocket rotation as end of side and auto-reverses. Take it to a shop.
Posted on Mar 19, 2010
Tape player wont play tape for 1997 explorer
Sounds like its time for a new radio. You've got an old Explorer like me. Check out - http://www.explorerforum.com/ I've received a lot of help here for a variety of issues.
Jun 30, 2014 | Audio Players & Recorders
Why does my sony reel to reel tape deck make no sound when playing a tape?
Are you playing the tape "right-side up"? I used to screw that up a lot at my radio station.
Jun 01, 2012 | Sony Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Jul 22, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
Cassette Deck doesn't auto reverse
This is a common problem....with tapes.....in the old days there was a shiny end of tape (EOT) sticker placed on the tape end which was detected as the tape end and caused the electronics to reverse the motor drive to play in the teverse direction.
If consumers alter the length of the tape by cutting and joining they used to cut off the EOT sticker and then the tape wouldnt reverse like in your case.
Now days a hi frequency signal is recorded on the tape and a detector circuit inside sees this signal and reverses the tape for you,
I would suggest that the simplest thing to do is to clean the playback head with a cotton bud and some special head cleaning alcohol.
There jusy may be a build up of magnetic material on the play back head which is stopping the high frequency signal getting through to the detector circuitry.
Different manufacturers do this EOT detection in different ways but the head clean is the first line of attack that you can do yourself.
Please turn off the power before doing this activity and be very careful with the cotton bud that you are not rough and dont push too hard on the recording/play back head.. Be gentle...
The cleaning liquid must be proper head cleaning liquid, so dont try shorth cuts and use just anything to do the cleaning or you may ruin the detector head surface.
The quality of play back sound will also improve from a good clean..
Cheers From YUBEUT
Sep 01, 2007 | Sharp XL-MP130 CD Shelf System
Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Apr 05, 2007 | Aiwa NSX-AJ20 CD Shelf System
 Grubhead
Grubhead
