Question about Irons
Kenwood iron Every time we buy an iron, after 2 years or less, when it has been used for more than half an hour, it trips the electricity. We have gone through about 5 irons like this. Each time, it costs far more than buying a new iron to have it repaired, so we throw out the old one, and get a slightly better one. Not very good for the environment. We now have a Kenwood, and the same thing has happened. It looks like there is dust in the soleplate, but I can't get the soleplate off to clean it. I managed to get the back cover off, by getting a special screwdriver from the hardware. Now there is something holding the front of the iron which I can't get off, to clean inside, and try to see what the problem is. Please can you shed some light on this, (explain the trick) or do all these irons only last for a short time, to fill up dumpsites? Do you think dust could be causing the shorting, or what could the problem be? Many thanks, Margaret
    Scholar:
  • 62 Answers
Yep! Cheap irons. This is par for the course with irons today. You might have a problem that could be fixed......however......
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Posted on Oct 08, 2008
Rotary iron kenwood used
If there are wires connected to the foot pedal, control is electrical, not mechanical. Contact eBay directly for resolution.
May 09, 2017 | Irons
Iron works for a little then electricity trips. why would this happen
You have a faulty and possibly a dangerous appliance. It could be a faulty/worn electrical cord. i suggest you get it checked out or throw it out and buy a new iron.
Dec 12, 2012 | Irons
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
May 31, 2010 | Euro-Pro Shark GI490 Iron
The electrical at home trips everytime I swicth ON the AZUR4330??
Hi
I know its hard to say... But please get a new iron....
You me y do more harm to other electricals just trying to fix the iron....
I know this is not a great solution byt a pratical one...
Warm Regards
Berry
Feb 02, 2010 | Philips HI-296 Iron
Bought iron model no 14722 less than a year ago cannot find reciept for argos how do i get new iron or repaired
You could try the store but I don't think you will have any luck. I buy most of my electrical items from one local store, so if I have lost a rec eipt they can look it up on their system. I recommend a Phillips Steam Iron GC 4430 Don't buy an iron from a supermarket.
Sep 10, 2009 | Irons
Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Sep 07, 2009 | Philips HI-296 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Clean sunbeam 4045 self cleaning iron
Make a solution of half water and half white vinegar. Fill up your iron and get is good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Sunbeam 4214 Iron
We have a fairly new B&D iron Cat # D2030 1. How does the "cleaning' work. The iron started to leak during ironing and it indicates "Cleaning". Do we need to do anything?. An excellent...
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
George
Apr 14, 2008 | Black & Decker D2030 Iron
G6118 Euro-Pro Iron
George
Mar 14, 2008 | Euro-Pro G6118 Iron
Irons Logo
138 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
