Question about Indesit Dishwashers
Indesit dishwasher model di620 ,led's flashing 1 an 3
  • 105 Answers
SOURCE: indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
IFIXALL
  • 868 Answers
SOURCE: Indesit dishwasher di620
You may have a electric control board that is out.Sorry but this D/W is going to be full of problems.
Posted on May 21, 2008
SOURCE: Indesit dishwasher DI620. It has
hold down the program select button until you hear a solid beep then it shoudl release
Posted on Jul 29, 2008
  • 8 Answers
SOURCE: Dishwasher fault codes
the heating element is probably bad.
i have a idl 600 here in naples italy and it would fill up and go into alarm light 2 and 4 and pump out the water.
heating element cost 28 euro and i changed it out.
had to change the clamps as well.
if you ohm the element it should show about 100 ohms.
if it is open its bad.
the mother board does some checks and if anything fails it alarms out and drains the water after a few minuts
ralph
Posted on Jun 13, 2009
SOURCE: indesit dishwasher error codes
why does the spray arm fall off?
Posted on Sep 07, 2010
Need manual for indesit dishwasher d1620 please
Visit this link to download the Dishwashers DI620 User Guide (pdf format)
Hope this helps (remember to rate this answer).
Jul 07, 2011 | Indesit 24 in. DI67 Free-standing...
ralph
Jun 02, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit DI620 but won't drain the water after a wash
are you finding water in the filter or is the appliance filled with water,if it is only in the filter at the end of the cycle,this is normal as it is used to condensed the steam after the 80o final rinse which drys the cutlery.if ithe appliance is filled then check the drain hose not partily blocked with grease or partly blocked at the sink if plumbed to there
Apr 28, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
May 20, 2008 | Indesit Dishwashers
Indesit di260
if its the latch tongue remove the top panel...if its the door remove the console
Aug 17, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
260 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
