Question about Prima CV1311 TV
Tv is sparking and making noise?
My prima tv is sparking and making noise every time the power is on i took it aprt to see what it was and its at the bottom of the tv around a cord connected to a part the cord runs to the top of the tv connecting to something that looks like a suction cup what is this and how can i fix it?
  • 4,234 Answers
The part with teh large red wire out of the top is as Azkeyz indicates the "flyback" transformer. This is the part that produces the high voltages required for the picture tube to function. As indicated, that wire conducts extremely high voltage that can injure anyone in contact with it. If there is sparking at the transformer end, then the part is beginning to fail. The sparking is due to a connection getting loose. The high voltage "jumps" the gap creating the sparking. This will only get worse. If the sparking is at the picture tube end, this can be fixed cheaply by carefully turning the rubber cap back and forth. Under that cap is a metal clip that can sometimes get a little dirt on it preventing good contact. That too will cause a spark.
PLEASE BE CAREFUL when attempting to work within the set. Even with the set unplugged, there is still a large amount of high voltage present. Think of the picture tube as a very large battery. THe high voltage remains for a very long time.
Dan
Posted on Sep 23, 2008
    Sergeant:
  • 300 Answers
Warning: Flyback Transformer Failure. ( extreme high voltage ) 22,000 Volts +
Do not attempt to fix this without another human being present who's trained in CPR.
Thank you for choosing FixYa!
Azkeyz, Wizard Division.
Our 2 year old Prima TV quit working. The power comes on, then as soon as picture tries to come on, the TV goes off. Called a repair man and is one of the parts for power, but Prima has gone out of...
gerneric should be able to be used as i had to work on a customers old prima and used some generic parts. ill try and find the link for you for the parts
May 14, 2011 | Prima CV2011 TV
Prima model number cv1311 will not power up
good day. there are some parts to be tested. just resolder all pins of jungle ic. make sure that the board has no loose connection, try to check them all. then try to on your tv.
Jun 21, 2010 | Prima CV1311 TV
What are the tv remote codes for Prima tvs when using universal remote controls like those owned by Dish Network?
We'rehappy to help you with programming your DISH Network remote to your Prima TV.Start by pressing and holding the TV button located on the top of your remoteuntil all mode button back lights come on, and then release. Use the numberbuttons to enter the codes for your Prima TV; here are some of the codes wecurrently have for it: 674, 653, 673, 912, and 842. Press the pound (#) button.To check that the code works try several different functions on the remote tomake sure it will properly operate the TV. Remember that some codes may not becompatible with your TV. If this is the case, try the other codes listed foryour Prima TV until you find one that is compatible with it. Ifnone of the above codes worked we recommend performing a power scan: Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jun 08, 2010 | Prima CV2011 TV
My prima tv suddenly says
You took the TV out of the mode for either satellite or cable and it need to be reset . check the user manual for the setting.
You didn't give model number for the unit/ I may be able to get you the instruction for you to reprogram the tv.
Apr 23, 2010 | Prima C2012 TV
I want to program my dish network remote to my prima tv
Hi my nameis Mike Houston of DISH Network. I see you are looking for the remote code toyour Prima TV, we do not have the three digit code at this time but we have away to program the remote to the TV through a Power Scan. I will send you thelink that will help with these steps, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jan 03, 2010 | Prima C2012 TV
Prima TV Model Q2016 comes on when plugged in.
the prima tV that co on as soon it is pluged in 90% of the time the Micro IC causes that proplem you need to replase the micro
Dec 14, 2008 | Zenith B19A02D 19" TV
Prima l080i
Magic smoke GONE!
Seriously, the main power supply has failed, and requires service. You are probably well past the warranty period, but check with the TV's service center - that information should be in the documents that came with the TV.
Jul 07, 2008 | Prima CV2011 TV
Prima combo tv does not come on when the power button is pushed or even with the remote
check the fuse first then, resolder the power supply of your tv.
Jun 20, 2008 | Prima CV1311 TV
Can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Mar 30, 2008 | Televison & Video
Televison & Video Logo
267 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
