Question about ECS 945P-A (V3.0) Motherboard
Ecs 945p-a install hdd sata
No possibile install hdd sata
  • Anonymous Dec 11, 2008
    I have my main C: drive connected to slot 1 but I am not able to install any other SATA drives. When plugging them in any of the 3 remaining slots the drives are not seen or recognised.
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug4 satas
Posted on Feb 24, 2009
Set bios to to enhanced. i have 3 hdd on my 945. btw this is the THIRD 945p-a motherboard that i have changed due to failure. after a while it will fail to boot. this is my last spare m/b that i will install. NO MORE ECS products
Posted on Dec 29, 2008
Xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Posted on Sep 23, 2008
Video card for 945p-a v3.0
Hello you can read all about the mainboard here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=672&CategoryID=1&MenuID=16&LanID=0
It should be compatibel with PCI-E
Good luck
Apr 26, 2012 | ECS 945P-A (V3.0) Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
What is the biggest HD I can install using the original BIOS (2006 version)
Yes you can install that drive. The only thing your limited on is the number of drives you can install..
Jan 27, 2009 | ECS 945P-A (V3.0) Motherboard
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
ECS 945P-A (V3.0) Motherboard Logo
422 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
