Computer screen there is power al-right but no screen
    Genius:
  • 1,124 Answers
Bad video card
bad inverter (laptop)
broken lcd screen
bad motherboard
Posted on Sep 25, 2008
I want to set my computer to new loose al the data i have how can i do that?
You can do a factory restore:
1. Shut down your computer.
2. Wait about ten seconds, then turn the power back on.
3. Keep pressing the F8 key while the power is coming back on. This will take you to the Advanced Boot Option screen. (NOTE: In some systems, the Advanced Boot Option screen is accessed by a different "F" key and it will tell you which "F" key needs to be pressed in order to access it. You can find out which "F" key is the right one during the power up screen.)
4. Highlight "Repair Your Computer" and hit the ENTER key. This takes you to the "System Recovery Options" screen.
5. Click "Restore Application." This will be the last option on the screen.
6. When you get to the "Recovery Options" screen, click on "Full Factory Recovery." Keep in mind that any factory-installed software will also be installed.
7. Click on "Next" when prompted, and then click "Yes."
8. Power down your computer completely. Wait 30 seconds, then power the system back up. Your system should now be restored to its factory settings.
Jun 25, 2012 | Toshiba G15-AV501 Qosmio Notebook
How do i set the alarm
Select on the top AL1 or AL2 depending on which alarm you want to set until that is selected on the screen in the upper right corner. Then press the AL Set button twice. Turn the +/- knob until you have selected the right hour. Make sure you set AM or PM when scrolling through (PM has an indicator, AM does not). Press the AL set button again. Then scroll through with the +/- knob to choose the minutes. Then press the AL Set again to make that your alarm.
May 05, 2011 | Homedics iSoundSpa Clock Radio with...
Al encender mi computadora me pide de inmediato password y no me deja ingresar al sistema. Como puedo desbloquear la clave de la BIOS para poder entrar a trabajar en windows?
o open the BIOS Setup screen:
  1. Turn off the computer and wait five seconds.
  2. Turn on the computer.
  3. When the first screen displays, immediately press the F10 key if your computer was built in 2006 or later (came with Vista or Windows 7). Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
    NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
  4. Use the keyboard to move through the menus.
  5. Then disable the Administrator PAsssword
Jan 20, 2011 | Compaq Armada 1573D Notebook
It says it does'nt support full screen mode...
right click it and ask troubleshot select your operative system and select the problem
Mar 12, 2010 | Sound Source Interactive Al-Qadim: The...
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
Setting alarm
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
Jul 04, 2008 | GPX HI2817 Shelf System
LCD Screen backlight problem
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
