Question about Whirlpool Dishwashers
My dishwasher, a Whirlpool DWF B10, is not cleaning properly. When the cycle has finished, there is always a block of undissolved dishwasher tablet/powder left behind. My guess is that the seal to the powder door has gone and allowing the tablet to get wet too early and part dissolve before the door opens - is this likely to be right? If so, can I get a replacement seal or do I have to replace the whole powder & rinse aid containers ??
  • 11 Answers
SOURCE: DISHES COVERED IN WHITE POWDER
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
http://www.dishwasher-care.org.uk/best.html
Posted on Nov 02, 2007
  • 6 Answers
SOURCE: dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
  • 630 Answers
SOURCE: Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Posted on Jul 02, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
SOURCE: Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Posted on Sep 11, 2010
Dwf 415 dishwasher, overfills with water
gee a whirlpool doing that
check the user manual
the control board failure
water level shut off sensor faulty
water pump failure
check for drain out blockages
http://lastmanuals.com/manual/WHIRLPOOL/DWF-415-W
Oct 13, 2016 | Dishwashers
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Why does the powder not dissolve properly
you must have really hard water . most makers no longer recommend powdered detergent as it undissolved will plug up a drain line totally
Mar 15, 2015 | Whirlpool Dishwashers
I have some problems with a Whirlpool DWF 406 dishwasher: The other day, my wife complained about it not finishing a program (just stopped and started bleeping). I saw a post at this forum where it said to...
We have the same problem. The dishwasher is 10 years old. In one of the German forums they said that usually it's because the sieve ahead of the membrane has a fine layer of sludge and the pump cannot pump out the dirty waste water. They said that you have to dismantle the sieve, clean it thoroughly, re-install it, and it should work just like it always did.
Nov 29, 2010 | Whirlpool Dishwashers
Whirlpool dwf b10 manual
Try this site
http://www.whirlpool.co.uk/support_instructions-for-use_instructions-for-use.content.html
then enter in DWH B10 and you should be able to download a PDF manual
Oct 12, 2010 | Dishwashers
Whirlpool DWF 407 IKEA Dishwasher serious problem.
a worn film capacitor on the circuit board is the cause of the problem which often manifests itself after several years using the dwf 407. Replacing the film capacitor on the circuit board is the solution! Such a capacitor costs about GBP 2. The removal of the circuit board that is in the door is not very difficult, four torque screws along the inside top of the door (not the two for the door lock) a click system in which the print is stuck in the door. On the print are a few connectors with wires to loosen-take picture or mark them for reassembly purposes. There are several types of DWF 407, sometimes the print is slightly different. But the culprit is always the big gray block. The value that you must have is 250/275 V 1,5UF. Many electronics stores have them or can order them. Soldering you can do yourself if you have some experience or ask your local handyman. It is not very difficult, you have plenty of space on the board and only two feet soldering required. After that my dishwasher was as new at the fraction of the price
Oct 28, 2009 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool DWF B00 W
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
Jun 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
DWF 413 dishwasher
What about the pump, did you checked it ? Does it drains water out the machin ?
Jun 27, 2006 | Whirlpool 24 in. DU850DWG Built-in...
Dishwashers Logo
52 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
