Question about Mitsubishi Televison & Video
I Have a Mitsubishi WS 55809 and the colors are seperated and the screen is bowed. From what I see on the internet it seems to be a convergence problem. I need to know how to fix this if I can do it myself. I really don't want to pay 4 or 500 bucks to fix it.
    Sergeant:
  • 300 Answers
Convergence Problem = Defective CRT board.
1. You can order a replacement CRT board.
2. You can trouble shoot the existing CRT board.
3. You can find search for an identical television set ( use imagination ) and do a CRT board transplant.
Do not monkey around with any convergence rings.
Thank you for choosing FixYa!
Azkeyz. Wizard Division.
Posted on Sep 23, 2008
Mitsubishi WS-65819 has convergence bows on top and bottom of the screen. The ic's stk 592-570 seem to be soldered tight to the circuit board. Wondering if the ic's are gone bad. Can you give be some...
Yes the ICs and Pico fuses need to be replaced. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the ICs and fuses plus the CD with repair instructions.
Feb 15, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Picture is bowed at top and bottom picture perfect in middle of screen; colors seperating in corners convergrence is perfect
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The colors are seperating and screen picture is bowing in?
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Convergence issues
You will find more info for identifing the ICs needed to fix your TV from the following link
http://www.fixya.com/support/r1122465-mitsubishi_convergence_ic_part_number
Aug 06, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 distorted picture
Sounds like you are having a convergence error.
What you could do is either replace the TV or have some wires/circuits/boards replaced.
Shop around for prices.
If you're lucky you'll find someone willing to do a free estimate, as replacing anything on these will set you back a few hundred...at least.
Hopefully, in your case, the problem can be solved by tightening a screw or two.
Jul 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cannot adjust convergence on Mitsubishi RPTV
as long as there is no bowing in the picture and the color does not want to move then there is probably just a bad resistor on the convergence IC that controls the color alignment , thus the resistors would have to be tested to find the low valued resistor on the IC
Nov 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
Harker, the convergence circuit has failed, IC`s and possibly a couple of support resistors, that`s a good set, call around to your local shops and get a few estimates, waay better set than the new dlp and lcd sets in my opinion, any questions? e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
