Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Viking VUd040 dishwasher hums but doesn't fill with water or rinse...
If I turn the left knob to dry, it make a humming noise and looks like it's trying to dry but when I turn the right knob to any of the setting like pots & pans or any other setting, it does nothing.
Is the timer knob broken?
By the way, I unplugged and plugged it back in and it didn't help.
Thanks a lot,
Fred
fredaabedi@yahoo.com
5 Suggested Answers
  • 205 Answers
SOURCE: Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Posted on Jul 21, 2008
Kgt1962
  • 59 Answers
SOURCE: Cycle just continues with the pot symbol blinking
disconnect the hose and run it into a bucket, is it pumping freely?.
did you check the trap for a blockage?
You may have a leak in the pump housing area below the unit, this would cause the drain pump to run continually.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: When I start the dishwasher it seems like the
Our problem, though for a different make and dishwasher, was solved by this link.http://www.appliancejournal.com/appliance-repair-help/dishwasher-repair-help/ge-dishwasher-repair/ge-dishwasher-motor-repair-problem-100/
Posted on May 05, 2010
SOURCE: Hi - my Viking dishwasher has developed a problem
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Posted on Oct 30, 2010
Just hums won t start
Their is 2 screens towards the back right that are plugged up. . You can take out 2 screws out and clean them up. Or the fill level adjustment in the front left isn't working right. It also can be fixed with 2 screws and cleaned.
Apr 21, 2014 | Haier Dishwashers
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
WATER DOESN'T DRAIN
if you acn hear a humming noise, then that is the pump energised but not rotating probably due to something stuck in the impellor
Dec 02, 2008 | GE Dishwashers
Left Knob Settings
goto northerparts.com and search your model.they may have a manual.try samsmanuals.com also.
Jan 05, 2008 | Viking 24 in. Professional Series VUD040...
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
