Question about Centon Electronics USB 2.0 PCMCIA (usb2pcmcia) Serial Adapter
Usb write protect
No switch
the disk is write protect error
cannot be formatted
  • Jeremy Acu
    Jeremy Acu Sep 23, 2008
    winxp
    everything updated
    from anti virus to windows
    tried windows format.. didn't work
    regediting "WriteProtect value to 0".. didnt work
    Scholar:
  • 87 Answers
If you've updated your software and checked the drivers but the issue still persists, try the following things:
  • Unplug the USB device and then plug it back in. Make sure that the connection is snug and installed in the proper direction. Note that USB plugs fit one way only—if you try to plug them in upside-down, it will not insert.
If this does not solve your issue-
  • Unplug all USB devices from the computer. Then start plugging in USB devices one at a time, testing each one to make sure they all work before adding the next. Sometimes two devices will conflict and will work together.
  • Is this a new device that never worked, or is it a device that you've had for a while that suddenly stopped working? If it used to work, think about what changed just before the device stopped working. Did you recently add another new device? Install a new program? Try reverting the computer to the way it was before the device stopped working. If it works again, there is an incompatibility with the device and whatever you added.
  • Unplug all but suspected USB devices. Open System Devices menu-
    • Windows: Right click “My Computer” > Properties > Hardware > Device Manager > USB Serial Bus Controllers
    Under the USB information, you should see the USB devices connected to your system. (Disregard any Host controllers) The name may not be identical to your device (it may say “USB Mass storage device”), but it should have the right number of devices listed.
  • If you have the device plugged into a USB hub or into your keyboard, plug it directly into one of the USB ports on the computer. If it works there, the issue is with the device to which it had been previously connected. The device may need more power than the port provides
  • Try a different computer!
Posted on Oct 24, 2008
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
Cannot format flash drive.... receive message `disk is write protected`
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Mar 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a kingston data traveller (pen drive)32 Gb which when i connect to the computer the drive gets detected but when i try to load some data into it, it give me an error message disk not found. When i...
Write protected and disk not found are the typical messages that a pc gives when you try to access a memory stick in which the actual memory chip has died. Nothing more can be done to fix it - it's dead. Junk it.
Aug 08, 2010 | Computers & Internet
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Remove Write Protection
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
May 18, 2009 | Kingston 4GB Secure Digital High Capacity...
Usb flash drive problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 11, 2008 | iLO (2 GB) MP3 Player
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Centon Electronics USB 2.0 PCMCIA (usb2pcmcia) Serial Adapter Logo
1,376 people viewed this question
Top Centon Electronics Computers & Internet Experts
David Payne
David Payne
Are you a Centon Electronics Computer and Internet Expert? Answer questions, earn points and help others
