Question about ASUS A8N-SLI Deluxe Motherboard
No video the thing will start & run.what happen is the video card is smoked.i only have pci video card.not getting any video.its a good card.what can i do to so i can find out what is wrong .before getting new card.or could the board be bad .just starting to build it.have good power supply, harddrive, memory ,amd athlon 64 ,please help.I no a little.but dont no **** about this board.
Get an old, inexpensive working graphics card from an obsolete PC and test your board with that (a pci one). If the problem persists it's almost sure it's a motherboard problem you will solve only with replacement. Try also removing BIOS battery to restore BIOS default settings. Unplug your system, locate the botton-shaped battery on your motherboard, remove it, wait atleast 15 seconds, put battery back in place and plug in your system's power.
Posted on Sep 23, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
I installed my video card and put it in the pci slot and plugged in the vga cable but when i reboot the computer and start it the computer runs but the screen goes blank (has worked in the past)
there is a good chance your video card (GPU) burned out i would try another card and see if the same thing happen so ud know if the motherboard slot has an issue or the card is the problem...
u can simply try a different slot also.
Oct 20, 2010 | Computers & Internet
Graphics card randomly stops working.does not shutdown computer but locks it up with monitor saying no picture is being sent to monitor. keep having to hard restart comp because of this ,does not alow for...
did u have this video card for long? did u do all your most recent video driver update? is your windows up to date with its patch ? what OS are you using?
one thing u could try is remove the video card from its socket check if the metalic contacts that goes into the pci slot is clean reinsert it if clean and try to restart your system if it still does the same thing.. it might seem simple but it might work ive seen this problem before and sometimes solved the issue that way....
it could be also just the fact that your GPU is overheating and it freeze your system due to that...
if its the case make sure your case has a good ventilation inside so fans are a must. one for air intake one for taking it out.
good luck
Oct 20, 2010 | BFG Technologies NVIDIA GeForce 9600 GT OC...
GT 5228, GATEWAY
What happened is your video card has burned out. If you are still using the video connection that is on your motherboard then what you need to do is go out and buy a new video card that will go into your pci slot inside your computer and then you'll connect your monitor to the new video card and your picture will be back up in no time.
Sep 29, 2009 | Computers & Internet
T2682 emachine running fine video lite went yellow & HD also
The first thing you should do is remove the video card and try to boot the PC using the onboard video (video on the Motherboard) and see if that solves the problem. If it does, try putting the video card back in in a DIFFERENT PCI slot and try it again. Sometimes Windows loses its marbles about cards inserted into PCI slots. My nieces eMachine loses its marbles over the Wireless LAN card about once a year, so I just move it to a different slot (swap it with the phone modem card). If that makes it flaky again, try updating the video card drivers. If it doesn't help, your video card is shot.
If it isn't the video card, try taking out one memory chip at a time and booting with the first one in. If that doesn't do it, swap the memory chip with the other one and try booting it again. If needed, replace bad chips....
After that, it is probably the power supply or the MB itself. Swap out the power supply first. If it is not the power supply, then it is probably the MB, and you are SOL.
May 10, 2009 | E-Machines T2682 PC Desktop
NO Video
Hi bigguy1967, the motherboard does have an 8x AGP slot.
Universal AGP v3.5 Compliant and Support 1.5V AGP Interface Only. Here is a link to a couple AGP 8x cards.
This is 1.5v compliant:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1892411&CatId=318
& this is too:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4297004&CatId=318
Good luck bigguy1967!
Mike
Jan 02, 2009 | PC Chips M963GV (V3.3A) Motherboard
No vedio
If a wire touched the side of the video card and there was a spark then that wire shorted something out. The video card is likely bad now and it is also possible that there was damage to the motherboard. If the motherboard still work then a working PCI video card or AGP video card would work. If there is damage to the motherboard from the short then it is possible that the PCI slots as well as the AGP slot will not work but there is no way to tell if that is the case without testing the electronics on the motherboard or plugging in a working video card to see if it works.
Jan 01, 2009 | PC Chips M963GV (V3.3A) Motherboard
Getting no single to my moniter
If your power light is on and no long beeps from your computer then is your intergrated video chip is bad. Your system board dosnt support agp or pci-e video cards. You will have to settle for a pci video card here is a good computer store to purchase one. http://www.mwave.com/mwave/Deepsearchdd.hmx?%CustURLState%
Jan 19, 2008 | Acer Aspire SA20 PC Desktop
ASUS A8N-SLI Deluxe Motherboard Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
