Question about Car Audio & Video
Kenwood KDC-1022 Unit works nicely but has no RCA output signal. Sheilding ground shows 0.5 ohm, so that much is intact but can get nothing to the amp...
  • Cursedknight Sep 24, 2008
    Nobody?
    cables are brand new and test fine, remote wire powers
    what's a pop test and how do I do one?
  • 53 Answers
Have you tried new rca cables or a pop test on the output to the amp ? maybe even a remote wire disconnected ? even though u get a .5 ohm reading the rca output could still be bad try a pop test on it this should help you figure out the problem
Posted on Sep 24, 2008
Subwoofer wont play
For a sub to play it needs wiring from sub to amp and the amp needs power from battery and amp needs signal from radio and amp needs to be grounded oh and it needs a remote signal from the radio as well and if your radio is stock and has no RCA outputs you need a LOC which will connect to you speakers with wire and to your amp with RCAs
Jan 05, 2014 | Kenwood KDC-MP642U
How do I hook up the auxiliary cable to a G1700 JL AMP from this radio?
the signal RCA cables and the power control wire go to the head unit. the power and ground go to + and - terminals, and the speaker wire goes to the corresponding clips on the speaker driver.
May 05, 2011 | Kenwood KDC-MP642U
Users manual kenwood kdc-1020 cd radio/cassette player
You can download and print the instruction manual for kenwood kdc-1020 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Dec 30, 2010 | Kenwood KDC-1022 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Kenwood KDC-MP438U acts as if there is no power to it,dead nothin
The speaker wires are very sensitive. You need to make sure that they are not grounding out. Once the unit senses this it will shut off. Pull the plug out of the back and start over.
Dec 30, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
I have a kdc-mp435u and when i connect the subs woofers to it,it dissent put out enough out put Signal to it and when im driving some times it give signal the woofers cussing them to hit heartier. I check...
did you plug your rca signal wires into the subwoofer ouput rca's? if so you can control the level and frequency of the sub on the face in the audio menu. if this is not the issue try new rca cables. you can run them outside the car first just to test. another issue is make sure you have proper grounding on the head unit and amp. also if your rca cables acccidently touch power they can blow a fuse or trace inside the radio causing the rca's to lose ground (you will have low audio with lots of humming noise). you can check this by jumpering a small wire from the radio frame to the outer shield of the rca jack while it is all plugged in. if the sound gets louder and cleaner you can secure this wire in place by soldering it or fixing the circuit board itself.
Dec 09, 2008 | Kenwood KDC-MP435U CD Player
Amp powers up (switchable) but has absolutely no output
If possible return the amp to the seller for a refund (before you tamper with it).
If that's not possible, the amp will need to be repaired. Do you want to try to repair it yourself?
For the head unit, you need to check the shield ground first. The following page will show you how to perform the test.
Shield Ground Test/Repair
Let me know if you have any other questions.
Sep 19, 2008 | Kenwood KAC-7202 Car Audio Amplifier
My kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Jan 23, 2008 | Car Audio & Video
Protection light turn on with sound
It's likely that the amp is defective but you should check the shield ground of the RCA signal cables before sending the amp off for repair.
Disconnect the RCA cables from the amp.
With your multimeter set to ohms, measure the resistance from the outer shield of the RCA cable to chassis ground. If it's more than a few ohms, that could be causing your problem.
If this is higher than a few ohms, short the meter's leads together to make sure the meter will go down to 0 ohms.
To check the shield ground of the head unit (assuming that the head unit is driving the amp directly), disconnect the RCA cables from the head unit and measure the resistance from the RCA output shield to the case of the head unit. It should essentially read 0 ohms.
Oct 21, 2007 | Cerwin Vega XL 600.1 Car Audio Amplifier
Can I plug an mp3 player into the unit ???
Hi, A wild guess, the 2 X RCA are lineout intended for external amplifier hence no AUX selection in your front panel buttons, but of course I might be off. I have similar problem with a Pioneer model and an MSI MP3 player. My solution was to install a stereo FM RF Modulator similar to Delphi SA10003 or an AudioVox Rf Modulator FMM100a. The MP3's output was fed to the modulator which turns it into an FM broadcast. The car stereo picks it up as an FM signal. Hope this gives you some idea. Good luck and kind regards.
Jul 31, 2007 | Kenwood KDC-1022 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
