Question about Cuisinart DGB-600 Coffee Maker
Pluged coffeemaker into power, time went on, then no power at all
  • crocket62 Sep 23, 2008
    I dont think the reports are correct
  • crocket62 Sep 24, 2008
    can not locate the fuse as to where you say it is
    Master:
  • 726 Answers
Can u please check these
  • the AC cord;
  • the jack where the cord plugs into;
  • internally, the fuse or thermal fuse (standard fuse would react to current, thermal fuse would react to temperature);
  • thermal cutoff/switch;
  • heating element.
  • all coulld be a problem
Posted on Sep 24, 2008
    Brigadier General:
  • 6,966 Answers
Like most electrically powered kitchen appliances, your coffeemaker is made up of several components that has to be checked individually. Foremost in mind would be:
  • the AC cord;
  • heating element.
Incidentally, you could also of course try the coffeemaker in another outlet. Back to the unit itself, all could be checked with the use of a continuity tester or a DVM. However, to be able to perform these, the unit (bottom) has to be opened. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 23, 2008
  • Cuisinart Master
  • 19,396 Answers
Try first a different socket.
If you are in UK or in a country were power plug is fused, check the fuse inside the plug.
If it still does not work, the machine must be taken apart, there is a fuse on the power adapter inside the machine, near to where you get the wires coming into the machine.
If fuse is ok, then some wire inside the machine have had a short circuit and has blown.
    Sergeant:
  • 399 Answers
Powerr short in the connection.check it properly.
thanks.
  • 1 more comment
  • masterexpert Sep 23, 2008
    wires are broken in between replace the power supply wire.first check the the current in the wire through continuity, detect where it is short and change the wire from there.or may be the fuse of the cofee maker inside on the main circuit board blown that also leads to no power problem.
    feel free for further queries.
    thanks.
    finally try to connect the power cord of the coffe maker in different outlet as the outlet where you are connecting at present must not be working.so connect somewhere else else in different outlet.
    thanks.
    it also causes due to dust or moisture collected on the main power supply board so get the machine serviced to avoid such problem further.
    reply for any further assistance
    thanks.
My mr. coffeemaker beeps 5 times and doesn't brew the coffee I just purchased this coffee pot last month aug 2014. what could be the problem
I see two problems that you've described.
First, you have a bad empty-reservoir sensor. Mine went out on my first Mr. Coffee within the first month also. The purpose of the sensor is to trigger the beeping to simply let you know when the coffee is done. The coffeemaker would normally work fine otherwise.
Second, you have a bad heating element. This is the core function of your coffeemaker and renders it useless for anything but a nice warming plate.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Sep 21, 2014 | Mr. Coffee Coffee Makers & Espresso...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
Cannot get the top cover removed so I can troubleshoot the electronics. All accessible screws removed. Seems to be some sort of catches where the side and top covers come together at the rear. Anybody done...
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
clean light glows, turn the coffeemaker on by
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
mode. One cycle should be sufficient to
adequately clean the coffeemaker. When the
cycle is completed and the five beeps sound,
the coffeemaker will shut off. Turn the
coffeemaker ON to see if the Clean light
continues to flash. If it does, turn it to OFF and
then repeat the cleaning procedure with a fresh
solution of vinegar and water.
If the Clean light no longer flashes, turn the
coffeemaker to OFF and then run one cycle of
fresh cold water through the unit before using
the unit again to brew coffee.
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OF
Mar 21, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
I lost my manual on how to use the self cleaning on my cuisinart coffee machine
Decalcification
coffeemaker.
the Clean Mode and turn the coffeemaker OFF.
Directly from the DCC-2400STR manual
Feb 14, 2010 | Cuisinart Coffee Makers & Espresso...
Cuisinart DCC2000/how to set it to keep coffee warm for 4 hrs
From my Cuisinart DCC-2000 Series Manual: The AUTO OFF feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours.
To program the Variable AUTO OFF:
1. Turn the function knob to "Auto Off". Press and hold the "Hour" button for 2 seconds. The clock display will start blinking.
2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the "Hour" and "Minute" buttons (see "TO SET THE TIME").
TO SET THE TIME:
1. Turn the function knob to "Clock".
a. SET HOUR: Press and hold the "Hour" button to scroll through numbers quickly. When number displayed approaches the desired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct hour, the default will be the last time set unless power is shut off.
NOTE: When the number count passes 12, the PM light will be displayed on the LCD.
b. SET MINUTES: Press and hold the "Minute" button to scroll through numbers quickly. When number displayed approaches the disired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct minute, the default will be the last time set unless power is shut off. To finish setting time, turn the FUNCTION KNOB to any other setting or simply wait until the numerals stop blinking.
(P.S. The picture of the coffeemaker shown above on this page is not the correct model I have as a DCC-2000. The picture shown has a coffee pot. The DCC2000 has a coffee reservoir and a dispensing lever for dispensing coffee into mug or cup.)
Jun 13, 2009 | Cuisinart Coffeemakers
Need Manual for Krups coffeemaker AG E 15 - can't set time
I went to the Krups web site and pulled a copy of the manual for a different model with the same user interface. This solution worked fine. My model (on the baseplate) is AG E 15. The manual that I printed was for a FMF5. Cheers!
Mar 30, 2009 | Krups Small Appliances Espresso Machine
Cuisinart DGB-600 Coffee Maker Logo
498 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
