Question about E-Machines Computers & Internet
When i try to type in my administrator password the ok is not high lighted and the enter wont work as well
  • 326 Answers
Depending on what program your using the password on, the ok wont highlight untill you have all the right amount of letter in the password tab.
etc
if your password is password and you only type passwor, the ok button wont highlight untill you put the d in. not sure if this is your problem but ive had it on certain programs.
Posted on Sep 23, 2008
How do i get my password
If you want to change a computer's sing-on password without actually knowing the original password, then today's your lucky day.
You don't need to be computer savvy to do this.
This is considering you know the ethics of privacy.
Please do not use this against anyone.
Okay, now that that's over with, here's how to change the sign-on password to a computer without knowing the original password...
Go to the start menu, then click on "run" (the command program).
Type in "cmd" (without the quotes).
Once the command window comes up type in: "net user"
After you type in "net user" it will list the user names of the computer.
You want to type in "net user" and the user name after it.
So if the username was Maya you would type in: net user maya.
After this it should say on the command window "you may change your password".
To change the password type in what you typed in the previous step but this time add the password to the end.
So if my password were abcd I would type in : net user maya abcd.
Change Administrator password using DOS Command
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Apr 10, 2014 | Computers & Internet
Tip
Methods to reset your Windows XP password
There is nothing to worry if you forgot your Windows logon password or if your password expires. You can reset your Windows password by following instructions given below.<br /><br />You cannot reset password unless you have reset disk or can log on as an administrator. You may need to reinstall your operating system before using computer again. This is an essential safety measure setup by Microsoft Windows. Without this, anyone could change a password of anyone's computer. <br /><br />Reset Windows XP Home Edition Password<br /> <br />There are two methods to reset Windows XP Home Edition password<br /><br />First Method: <br /><br />To reset password you may need to log on as an administrator. Follow steps mentioned below to log on as an administrator <br /><br />a. Reboot the PC.<br />b. Press CTRL+ALT+DELETE couple of times, and then type the name of the administrator user name or just type 'Administrator'.<br /><br />c. Type your administrator password in the password field, and click OK. If you do not know the password, leave it blank, and click OK. <br />d. Press Start button on the taskbar, and click Run.<br />e. Enter control user passwords 2, and click OK button.<br />f. Open Users tab, select the user account form the list that you want to reset the password for, and press Reset Password.<br />g. Select a new password and Enter it in the new password field and then type that password again in the confirm password field, and then press OK.<br />h. Reboot the PC, and try logging in to the computer. <br /><br />If your computer is a member of a domain then follow these steps:<br /><br />To log on to the window as an administrator: <br /><br />a. Reboot the PC, and press the F8 key during the boot until the Windows Advanced Options menu appears.<br />b. Select the Safe Mode option, and press ENTER key.<br />c. Select Microsoft Windows XP edition, and press ENTER key. <br />d. Click your user name screen button, then click Administrator, and enter the administrator password in the password field.<br />e. Press ENTER key, and click Yes. <br /><br />To reset the Microsoft windows password:<br /><br />Click Start button on the taskbar below and then click Run.<br /><br />f. Enter control user passwords 2 in the text field, and click OK.<br />g. Pick the logon user name for which you want to alter the password.<br />h. Click on Change the Password, and enter a new log on password. <br />i. Press Change Password button.<br />j. Reboot the PC, and then log on to the windows. <br /><br />The Second Method: Using a password reset disk<br />To log on to the computer by using a password reset disk, follow the steps outlined below. <br /><br />Reset password for Windows XP Professional Edition<br /><br />1. Reboot your PC.<br />2. Click the user name, you'll see an error. <br />3. Click on the Use your password reset disk. The Password Reset Wizard window will open.<br />4. Click Next.<br />5. Insert the password reset disc into the CD/DVD drive, and click Next.<br />6. Type a new password and confirm the password in the required fields, then click on Next.<br />7. Click Finish, log on to the PC again. <br /><br />
on Jan 18, 2011 | Computers & Internet
I CAN NOT GET ON LINE ,MY id WONT WORK NOT MY PASS .
With the information you have provided it is hard to say what the issue might be. Could you please be more specific in what is happening? Is it password related to the PC? Is it sluggish performance? Is it missing program links? is it internet access?
Mar 25, 2014 | E-Machines eMachines Desktop PC
Lost administartor rights
Click start Control Panel. Select "User Accounts and Family Safety," then "User Accounts." Click "Turn User Account Control on or off." Remove the check mark next to "Use User Account Control (UAC) to help protect your computer." Click "OK." Set All Accounts to Administrator Still in the UAC section of Control Panel, select "Manage another account," and click on a user account. Click on "Change the account type." When working with multiple accounts, some changes can only be made if you and the account holder are both logged in with "Administrator" accounts so you need to change all user accounts to "Administrator." When you are done making changes, you can change them back to "Standard," but always leave at least one "Administrator" account. Select the "Administrator" radio button. Click "Change Account Type" at the bottom right. Repeat this procedure to change each user account to "Administrator." When all user accounts have been changed, close the Control Panel. Create a Full Administrator Account Click "Start" (the Windows Vista icon in the lower left of your screen). In the Search box, type "cmd". Right-click on "cmd," and select "Run as Administrator." An elevated command prompt window will appear. At the command prompt, type "net user administrator /active:yes", and press "Enter." Choose a password and assign it to the "Administrator" account, by typing "net user administrator 'password'", where 'password' is your selected password. For instance, if your password is "abc," type "net user administrator abc". Press "Enter." Type "exit" and press "Enter." Log off. When you log back into your "Administrator" account, you will have full rights.
Jan 25, 2013 | Microsoft Internet Explorer 9
Do i have an acount
Click "OK."
hope this helps
Sep 28, 2012 | Computers & Internet
Retrieving administrator settings
Click "OK."
hope this helps
Sep 17, 2012 | Dell Inspiron 530s Desktop Computer...
Forgot password to get into windows
When I forgot Lenovo Windows 8 password, I got Windows Password Recovery Tool Ultimate to support me make a password reset disk with USB and reset password efficiently!
Apr 30, 2010 | Computers & Internet
I have a inspiron 1100 laptop. I cannot remember my login password. Please help, any suggestions?
This question has been asked (and answered) hundreds of times. Here is the best answer I pulled up for you.
http://www.windowspasswordsrecovery.com
Oct 25, 2009 | Dell Inspiron 1000 Notebook
Vista
you can try these steps:
1. Boot from the OS cd
2. On the language settings screen, click the appropriate language in the Language to install list, click the appropriate time and currency format in the Time and currency format list, click the appropriate keyboard layout to use in the Keyboard or input method list, and then click Next.
3. On the lower-left corner of the Install now screen, click Repair your computer.
4. If the Windows Vista Setup program detects any problems on the computer, click No when
the program displays the following message:
Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?
5. In the System Recovery Options window, under Operating System, click Windows Vista (TM) Version, even if this entry is already selected, and then click Next to display the Choose a recovery tool window. Choose Command Prompt.
6. Type: c: (enter)
7. Type: cd windows\system32 (enter)
8. Type:echo ~takeown /f %1 /r /d y > TakeControlOf.cmd (enter)
9. Type: echo ~icacls %1 /grant administrators:F /t (enter)
10. Type: ren Magnify.exe Magnify.old (enter)
11. Type: ren cmd.exe Magnify.exe (enter)
12. Restart the computer
13. Click the Ease button on the lower left of the screen
14. Check the Make items on the screen larger (Magnifier) then click OK
15. Type: net user Administrator /active:yes (enter) – capital A
16. Type: exit (enter)
17. Restart the computer
18. Logon to the Administrator account
19. Access the "User Accounts" then remove the password of the user account that is blocked
20. LogOff then Access the account that was previously blocked to try if its accessible
21. Goto "c:\windows\system32"
22. Right click Magnify.exe -> properties -> Security -> Advanced -> Owner -> edit -> Administrators -> Ok
23. Edit -> Administrators -> Full Control -> Apply -> Ok
24. Rename Magnify.exe to cmd
25. Right click Magnify.old -> properties -> Security -> Advanced -> Owner -> edit -> Administrators -> Ok
26. Edit -> Administrators -> Full Control -> Apply -> Ok
27. Rename Magnify.old to Magnify.exe
28. Launch Command Line
29. Type: net user Administrator /active:no (enter)
Good luck. :)
http://tinyurl.com/ye2q2kv
Sep 28, 2009 | Microsoft Windows Vista Ultimate with SP1...
I have forgotten the password that i used when opening my account. please assist. thank you phill rogers
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
