need a service manual for dissasembly and the circuitry schematic for a RCA d52w19 does any one know where to get oneneed a service manual for dissasembly and the circuitry schematic for a RCA d52w19
You can't post conmments that contain an email address.
www.scribd.com/.../RCA-Chassis-CTC203-TV-Trainning-Manual images.thomann.de/pics/prod/113142_smanual.pdf It could be one of many many things, please use these training and service manual, to try an isolate your issue and repair.
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
is it a off white block with a pink wire set going to the 3 picture tubes?then it is the high voltage called a flyback transformer.
the output is 28000 volts.you have to discharge the tubes before replacing the anode caps which are connected to the flyback.
this is a severe shock danger.
do not attempt this without the service manual ,about 35 dollars from rca.
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
