Question about AOpen 1557GL Centrino Notebook, 15" LCD PC Notebook
MEMORY CARD My slot for memory card does not work any more when I insert a MS (Memoy stick)
  • manufla Sep 23, 2008
    Please help me with this problem
  • Roberta Smith
    Roberta Smith May 11, 2010
    Plug another device into the usb port to narrow down whether it is your usb flash drive or the usb port on the computer.
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memoy stick pro dou and my p900
SE P900 does not support memory stick pro duo. it' s only support MEMORY STICK DUO (w/o PRO). i have the same problem too. my p900 only live with 32MB MS DUO and there are no more MS DUO in my city (even SE's service center)
if you wanna use your MS DUO PRO, then you'll need to upgade to P990i or P1i. that's much better then P900i (newer OS, more ROM, new keypad, plus WiFi) :D
Dec 24, 2008 | Sony Ericsson P900
I have a simple question. How do I insert my scandisk memory stick pro duo card into my laptop to read? MY laptop has open slot 5 in 1 media card reader. I can insert all my other card and able to read....
You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
Dec 03, 2008 | SanDisk Memory Media
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
How to insert memory card?
see manual which can be downloaded from
It might be that the Sony MS belongs within another cart slot.
Jan 18, 2008 | Brother DCP-110C All-In-One InkJet Printer
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory StickĀ® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
AOpen 1557GL Centrino Notebook, 15" LCD PC Notebook Logo
37 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
