Question about Canon XL1S Mini DV Digital Camcorder
Canon XL1 does not power up properly
Hi, I have a Canon XL1 that works perfectly in video playback mode, but here is what happen when I try to use it in any of the record modes:
The red power light turns on and does not blink
The audio level indicator LCD turns on, and shows what mode the volume controls are currently operating in
The LCD eye display turns on, but show a black picture. (The back light is working, but it's actually displaying a black picture)
The time code display shows all dashes for the time code, and SP recording mode
about 5 or 10 seconds later is turns itself back off.
Here are some things that I've already tried:
Removing the lens and running it with no lens.
Running it on both batteries and power supply
I tried running it with no memory battery
I tried running it with no eye piece
I tried running with and without a tape in the deck
I tried running it on every record mode
All have exactly the same result
What is causing this problem? Do I need to replace or repair on of the circuit boards inside, or is it something very simple?
Thanks ahead of time for the help!
  • Anonymous Nov 14, 2008
    I have the same issue, only mine does not stay on for 10 seconds. It stays on for about 2 seconds - not even long enough to get a blue screen in the viewfinder. Then, it automatically shuts off. I've tried batteries and direct power with the same result. Playback works just fine. Any solutions? Mine is a Canon xl1s.
5 Suggested Answers
philipp
  • 217 Answers
SOURCE: no picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
Posted on Sep 18, 2007
zohail
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
SOURCE: Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Posted on Dec 21, 2009
rommelalilin
  • 2178 Answers
SOURCE: My canon camera seems to work fine in record mode.
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Posted on Nov 13, 2010
Good Day,... When i record with my canon XL1 for 30 mini. , And playback the video i get a mosaic-like noise
This is often caused by digital dropout. Try cleaning the heads and report the results. If the cleaning fails to resolve the problem, we can look for other possibilities, but lets eliminate the simple stuff first.
Thanks,
Dan
Apr 29, 2010 | Canon XL1S Mini DV Digital Camcorder
IMovie and Canon ZR500 no image
I have a slightly different but related model of Canon camera. I have found that if you erroneously power it on in "camera" mode instead of "playback" mode, you get the symptoms you describe: you can control the camera with iMovie, but you can't get any video out of it. Make sure you have the power switch in "playback" position -- it's an easy mistake to make.
Nov 12, 2009 | Apple Power Mac G5 Desktop
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Aug 30, 2009 | Canon HV10 HDV Digital Camcorder
Camera no power
You are right. It is not the battery. XL1s may have a blown transistors in the power PCB. It probably would not damaged any other are but power. This symptom requires a disassembly and removal of power PCB and repair. Sorry, I could not give any quick resolution for this. James. For further assistance, go to www.camerarepairjapan.com
Mar 24, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon xl 1s won't power up. Power light flashes, screen lights up then it turns it self off..will keep repeating like this every few seconds but won't stay on help
Just fixed this problem. It is one of the three main fuses that have blown out. This is not supposed to be consumer accessible or fixable, but I did it.
Open up the camera case using the 5 allen head screws disconnect the top ribbon cable going to the playback buttons on the handle. on the main board (behind the tape deck) are 3 tiny square black fuses The top fuse FU3201 is the VTR The middle fuse FU3200 is the Motor The bottom fuse FU3202 is the Camera/Lense
The bottom fuse was my culprit. I found a tiny piece of copper and bent it into a U shape and slipped it over the fuse so that it touched the metal terminals on both sides and bypassed the fuse. This fixed the problem.
Haven't used the camera extensively since, but shoot about 10 hrs a week with 2 xl1's and will post if anything happens.
Here is a diagram from the Canon XL1 Service Manual: http://www.coycypert.net/files/xl1.png
Here is the service manual download link: http://www.coycypert.net/files/CANON%20DM-XL1.pdf
Feb 20, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon xl2 playback
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Nov 14, 2008 | Canon XL2 Mini DV Digital Camcorder
Canon XL1
I paid the premium service but your tech knew less about the camera than I did. He didn't know the Canon XL1 at all. His directions indicated he had no idea how the camera worked.
Jul 12, 2008 | Video Cameras
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
http://www.fceconverter.com/mod-to-final-cut-express/
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
No picture in rec mode, cam switches off in 10sec
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
atdlee@netzero.com
Dec 24, 2007 | Canon XL1S Mini DV Digital Camcorder
Taking photos or video works sometimes
Hi, I think this is problem due to LCD Diplay. Sangita
Jul 23, 2007 | Canon PowerShot SD1000 Digital Camera
Canon XL1S Mini DV Digital Camcorder Logo
102 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
